Nailing Vs. Screwing
Old 01-10-2009, 05:59 PM   #41
herbabuena's Avatar
Re: Nailing Vs. Screwing
Thanks everyone for the informative discussion so far.
We are about to install a strand-woven bamboo floor and want to use screws with pre-drilled holes. For those of you who have suggested a screw-down installation of hardwood, do you have any particular suggestions about the type of screw?
Also, I've also read suggestions on here about milling out the groove over the tongue to decrease dimpling. Any comments about depth and angle?
Thanks!
herbabuena is offline
Old 01-10-2009, 09:35 PM   #42
NoClone's Avatar
Trade: home improvement contractor
Originally Posted by Bill View Post
I prefer to glue and screw down subfloors especially on high end jobs. Guarenteed no call backs. Worth it to me
I completely agree! It takes a little longer, but no problems and no call backs....That makes everyone happy!
NoClone is offline
Old 01-15-2009, 06:38 PM   #43
I like Green things
WarnerConstInc.'s Avatar
Thanks!
Seriously, you are an idiot. I told you that before, you edited the post now I find it again.
WarnerConstInc. is online now
Old 01-15-2009, 06:51 PM   #44
Thanks!
I think his name is
"Good Herb" maybe
explains a lot.
neolitic is offline
Old 01-15-2009, 07:14 PM   #45
I like Green things
Could you imagine pre-drilling all your flooring like that? Then having to plug all those holes? Hope no one sees my new kitchen floor when I am done with it, wide plank ash face nailed with cut nails.
Wow is all I got!!
Old 02-05-2009, 08:36 AM   #46
CK1
clkconstruction's Avatar
Trade: General Contractor, Electrical, Finish Framing
I recently got a call from a home owner who is sick of their squeaky floor. I normally would pass this off to the next guy but in this economy...
What is the best way to remedy this problem without too much damage? I'm not sure how far they are willing to go in order to gain access to the sub-floor. I am guessing they have carpet.
clkconstruction is offline
Old 02-05-2009, 09:00 AM   #47
I like Green things
Go to Ace and buy the kit with the screw and pedistal, the screw breaks off under the carpet. Its like 20 bucks.
clkconstruction (02-05-2009)
Old 02-05-2009, 09:36 AM   #48
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Hire a carpet guy to break the seam at the doorway, pull the carpet back, install screws into joists at squeaky areas, re-seam & re-stretch carpet. Its actually pretty common.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 02-06-2009, 03:38 AM   #49
simplejack's Avatar
Trade: General
Question
If you use the right Glue, will the nail still squeak?
I'm a commercial Contractor so I know my way around a screw gun Way better than a hammer, but I was under the impression that screw heads tend to weaken due to the torque needed for wood on wood fastening, making it more likely to break in a strong shift, and that nails should be used with glue on sub flooring.
Is that no longer an issue with today's screws?
simplejack is offline
The Following User Says Thank You to simplejack For This Useful Post:
Forry (02-06-2009)
Old 02-06-2009, 10:02 PM   #50
Patterson Remodeling LLC
PattersonRemod's Avatar
Trade: Remodeling & Flooring
We're a building and flooring company out in az and we've had great success with the designed HARDI BACKER screws specifically made for 1/2 and 1/4 in backer board if used properly the hardi backer screw company will warranty any problems due to the install
PattersonRemod is offline
Whats everyones choice on nailing the last 18" of flooring next to the wall? TurnkeyConst Flooring 27 01-26-2009 10:15 AM
GAF nailing strip Jaketoo Roofing 12 08-10-2007 07:58 PM
Finish Nailing Problem mms Finish Carpentry 8 03-29-2007 10:40 AM
Nailing Strips for Crown Mpeters Finish Carpentry 5 02-24-2007 08:53 PM
Screwing down deck boards JPV123 Carpentry 32 10-24-2006 10:25 PM
