#21 |
Knowledge Factory
Re: Nailing Vs. Screwing
Coarse thread drywall screws will work. They are a little brittle and snap the heads when they get in a bind, but you don't have to worry about rust, as there is more moisture involved in taping and floating a drywall job, then rolling out asphalt impregnated felt.
#22 |
Flooring Installer
Trade: flooring
I have installed flooring for 35 years. It is better if underlayment is stapled.
#23 | |
Poo Flooman
Trade: C-15 flooring
Re: Nailing Vs. ScrewingQuote:
Screws will hold better if they are the right ones. All screws are not the same. The ones for sub-flooring have a reverse thread just below the head to force the sub-flooring down tight. Otherwise you have a better chance of loose or creeky floors if no glue was used. For me, I use ring shanked cement coated nails in my Senco and call it a day. Anyway, I'm new to the forum but been installing floors for 27 years. Hope I've helped
#24 |
egotistical prick
Trade: Wood Inlay
Screw and glue. Keep using nails so I can go back and get it done right and charge more!
#25 | |
Plumber / Carpenter
We had to go back on one because of a squeaky spot due to the nail did not pull the plywood down. The subfloor was riding up and down the nail. |
#26 | |
egotistical prick
Trade: Wood Inlay
#27 | |
Poo Flooman
I hope this site is not filled with people like this, maybe just a bad apple in the bunch. They build with nails, the code is a nailing schedule. All those sub-floors that are installed with nails and up to code are what?Some people spend their whole life in the box. I wonder if Cdat puts 3/4" plywood sub-floor, over concrete, with screws and glue. I suppose on each sheet of plywood he could drill 42 holes in the concrete, plug them, spread the glue and then screw the plywood sheet down. Hence screwed and glued plywood sub-floor done right. Let's follow this guy, he knows where he's going. Furthermore, I hope Cdat isn't one of these guys that uses the wrong screw or cheep ones and doesn't sink them all the way and leaves the heads up. Because all I can do is to fix this problem after is to hit them with a hammer, break the head off and put a nail there. Now try and tell me that you're the only floor guy that sinks all the screw heads. LOL |
#28 | |
egotistical prick
Trade: Wood Inlay
#29 |
Plumber / Carpenter
Code is minimum requirement, that does not mean its the best thing to do
#30 |
egotistical prick
Trade: Wood Inlay
Re: Nailing Vs. Screwing |
#31 |
Plumber / Carpenter
there you go! i usually try to go above and beyond code requirements myself. Just looks and lasts better.
#32 |
Trade: Realtor
If you would like to permanently keep the flooring, nailing should be better due to the fact that it is much stronger than screwing. However, screwing should be very helpful if you are planning on removing the flooring.
Hope i was helpful, John |
#33 |
Plumber / Carpenter
Not true. As stated before even ring shank nails will turn lose after time. Smooth shank nails will pull out also. You simply can not pull out a screw like a nail.
#34 | |
Steve
. Subloor is glued, tacked w/nails, then screwed with flooring screws. Underlayment stapled.
#35 |
Plumber / Carpenter
Yeh, I thought the same thing, realator. Guess they got into the home building business
#36 |
Steve
Hey 45, what happened to your old avatar? Everytime you post it's a different one. I liked the pistolis myself
#37 | |
Plumber / Carpenter
There you go! Last edited by Bill; 07-21-2008 at 08:10 PM. |
#38 | |
Poo Flooman
Not to get off the subject, I got a riddle for you guys. WHO JUMPS FIRST OUT OF THE AIRPLANE WITH NO PARACHUTE? A plumber, a fool or a carpenter. Since these guys haven't been laying floors very long............. WHO CARES!!!!!!!!!!!!!!!! |
#39 |
Rock it...
dude look at his other posts. he is just whoring it up. Nailing may have more sheer strength, but I don't know if thats a big issue or not. I screw and PL40 but Ive never gone back to a house Ive done after an earthquake either. I agree code is the minimum requirement for a lot of things I say do it your way as long as its above and beyond. As far as the angry flooring guy. Im not taking any sides, but what have you seen happen to a screwed down floor thats so horrific?This is your chance to teach me a lesson Because I am just a youngin and have seen lots of sqeeky floors from nails.
#40 | |
egotistical prick
Trade: Wood Inlay
| Whats everyones choice on nailing the last 18" of flooring next to the wall? | TurnkeyConst | Flooring | 27 | 01-26-2009 10:15 AM |
| GAF nailing strip | Jaketoo | Roofing | 12 | 08-10-2007 07:58 PM |
| Finish Nailing Problem | mms | Finish Carpentry | 8 | 03-29-2007 10:40 AM |
| Nailing Strips for Crown | Mpeters | Finish Carpentry | 5 | 02-24-2007 08:53 PM |
| Screwing down deck boards | JPV123 | Carpentry | 32 | 10-24-2006 10:25 PM |
