My Tile Project. Want Input!!
Old 11-07-2007, 06:38 PM   #1
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
Alright this is only my 3rd tile project. It is on a house i am building for myself. Just wanted to get input and see what you tile pros think. I actually enjoy doing it too. I figure its not too bad for a dumb roofer. Also what would you guy charge for doing this type of work. just wondering cause it is taking me for ever. I am using 4x4" ,and 12x12" tiles as well as smaller trim pieces. and I know i have a few spots to fill in. Thanks for the comments good or bad.
Patriot Broadcasting Network
doubleaction is offline
Old 11-07-2007, 07:26 PM   #2
barreled's Avatar
Re: My Tile Project. Want Input!!
Looks really good I would charge $8 to $10 per sq foot, just labor. I dont do much tile but that has been the going rate here.
barreled is offline
Old 11-07-2007, 08:21 PM   #3
Old school Ranger
floorinstall's Avatar
Trade: flooring
it needs grout
floorinstall is offline
Old 11-07-2007, 08:28 PM   #4
send_it_all's Avatar
The quality of installation looks pretty good to me. It is a little busy for my taste, but that doesn't mean anything.
send_it_all is offline
Old 11-07-2007, 08:31 PM   #5
It is what it is
Originally Posted by floorinstall View Post
it needs grout
Damn it, I knew i was forgetting something.
Old 11-07-2007, 09:39 PM   #6
Home Serve's Avatar
Trade: siding windows soffit fascia
Me too, about 8-10 dollars a square foot is best, bigger job would knock it down some.
NICE JOB on yours there!!
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 11-08-2007, 08:37 AM   #7
Trowel Monkey
Shaughnn's Avatar
Trade: Tile & Stone Contractor
Hello Doubleaction,.
The installation looks really good. I think that the pricing that people are suggesting is generally low. For a standard 4'-by-3' shower that's less than $800 for labor, which isn't quite my daily minimum for two days. You've got a diagonal installation with varied-sized stone, mosaic elements, several complex liners and the base of running-bond pattern. Did you have to cut those pieces down yourself or did you purchase them in those sizes? I see that you used Redgard to waterproof everything also, so that's going to add another full day to the project, at least! Are you building a tiled shower pan or using an acrylic pan?
Some suggestions I'd make are that you increase the width of the horizontal band in the shower to eliminate the gap at the ceiling and I would have terminated the mosaic liner with a vertical pencil-liner, mitered like you did with that very cool cover-plate panel above the tub. I'm curious to know why you switched from 4-by-4s to 4-by-12s in the shower brick pattern?
Shaughnn
Shaughnn
Capua Custom Tile & Stone
Card-carrying Schluter Systems installer
Certified Wedi Corp. installer
Shaughnn is offline
Old 11-08-2007, 09:39 AM   #8
Knowledge Factory
Floordude's Avatar
On my profit margins, that type of work, would surpass $8-10 a sq. ft. A basic straight lay, on a vertical surface, averages $8-12 a foot, with extras added.
http://www.AustinFloorguy.com
Floordude is offline
Old 11-08-2007, 09:55 AM   #9
ak_aiken's Avatar
Trade: Flooring contractor
$8-$10 per foot is to low for me as well. There is just way to much going on in a shower; drypacking the pan, shower liner, water proofing all that stuff eats up the time, then when you add in the detail that you have put into your shower even more time goes into it. I would probably be in the $14+ per foot range just to set the tile everything leading up to that would be additional. Not to mention shower shelves, niches, and seats all that stuff is extra as well.
Nice job
ak_aiken is offline
Old 11-08-2007, 11:16 AM   #10
It is what it is
Shaughnn
I had to cut all the 4x8 for the running bond out of 12x12s. I am also going to terminate the mosaic liner with vertical pencil liner with mitered cuts too match the boxed outlet below. I was looking at that the other night and thought it would look better. I built a mud shower pan.
Old 11-08-2007, 06:10 PM   #11
tile mason
MattCoops's Avatar
I agree with Shaughnn,
Everything looks good except the bitty gap at the cieling. Could have made the border mosaic two rows higher.
MattCoops is offline
Old 11-08-2007, 07:29 PM   #12
It is what it is
Yeah thats why i didnt go any further i havent desided what im going to do up there yet.
Old 11-08-2007, 07:42 PM   #13
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Looks purdy...grouting always makes the job. That looks like natural stone, sealing it prior to grout would be advised...
woodmagman is offline
Old 11-08-2007, 07:44 PM   #14
Trowel Monkey
Shaughnn's Avatar
Look to me like the only alternatives are to continue the diagonal pattern OR border the top with the gold-colored slate.
Don't sweat it too much . It's a really nice looking job.
Shaughnn
Shaughnn
Shaughnn is offline
Old 11-08-2007, 07:46 PM   #15
woodmagman's Avatar
Why not use the brown boarder across the top aswell. You could carefully cut the top row with an angle grinder and tile blade without removing the intire tile and keep the boarder the same size. It would look finished then.
The first thing I noticed were the electrical outlets....so close to the tub. Does your building code not require some safe distance for swithes and outlets?
Old 11-08-2007, 08:36 PM   #16
It is what it is
They are actually going to be GFI resets for the pump and heater, i was waiting for someone to question that.
Old 11-08-2007, 09:35 PM   #17
GCC's Avatar
Trade: General
Why would you put gfci resets so close to the water source & why in plain view I would not make stand out so much..just me Tile job top notch!
GCC is offline
Old 11-09-2007, 09:26 AM   #18
CCSowner's Avatar
Trade: Tile/Stone
It looks good I would charge around 9 a SQ/FT Make sure you post pics of it grouted.
Thanks
Adam
Adam Forsythe
Creative Covering solutions
"New England's Answer to Brick paving and Tile/Stone"
www.creativecoveringsolutions.com
CCSowner is offline
Old 11-16-2007, 09:05 PM   #19
aardvark's Avatar
Trade: Remodelor / Handyman
Looks great, I love doing tile work like this. I can't make money doing this kind of work. $10, $15, now $20 per square ft. And I'm quick. I still loose money.
I've recently been using Starquartz(.com) grout. It'sexpensive but goes on great and • Pre-mixed and ready to use
• Self sealing, no sealing required
• Stain / chemical / mildew resistant
• UV resistant – light colors won’t fade or yellow
• Semi flexible, low shrinkage and highly crack resistant
• Leftover grout can be saved for the next job
So far so good. The other downside is that it's a sanded grout so I couldn't use it on glass tile.
aardvark is offline
Old 11-20-2007, 04:54 PM   #20
Tileguytodd's Avatar
Trade: Tile & Stone Contracting
I'm with Shaughnn ...Piece work like this is tedious & time consuming ( i think some of you missed the liners Perhaps?? )
I'd lowball this at 18 s/f if I really needed the work.......20 + if i were busy simply because this is NOT a profit job..This is a RESUME' job.
I dont need a resume after over 20 years
Therefor, I want profit.......I also want to keep my helper working (main reason for potential lowball price)
Guys look at this stuff and drool but in all honestly, IF you get known for this type of work and you cant get PAID for it......Whats the point. You might as well go work flipping burgers unless you want to be just another starving tile artist.
As for the gap...Try This:
cut lgtile to proper size squrae...(in other words..if that space equals 2.5" high cut strips 2.5" (less a dbl liner for top & bottom) and then square it at 2.5"(less a dbl liner) giving you 2or 3 pcs per 6" strip.(maybe 1.75" x 1.75" aprox)..NOW cut them on the diagonal Use the colors you have to advantage here....since you are doing this yourself play around till you get a nice geometric look to go with your GEO metric look LOL
Tilewerks
Tile and Stone Contracting
Warba,MN 55793
Tileguytodd is offline
To all The Newbies Starting Up Their Own Business dirt diggler General Discussion 53 04-27-2011 07:21 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Project Manager/Project Engineer ComConRecruiter Help Wanted or Looking For Work 0 03-28-2007 03:42 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
