Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 10-11-2004, 03:01 PM   #1
Unregistered
Guest
Trade:
Posts: n/a
MUST remove carpet's underpad?
I’m replacing carpet with laminate. Do I HAVE to remove carpet's cushion/underpad or I can put laminate’s underlayment on the top of it?
Thanks.
Old 10-11-2004, 03:47 PM   #2
Trade: Flooring
Send a message via Yahoo to Mike Costello
Remove he pad!!
Mike Costello is offline   Reply With Quote
Old 10-11-2004, 03:55 PM   #3
Unregistered
Guest
Trade:
Posts: n/a
why? it looks perfectly fine ;-))
Old 10-11-2004, 04:26 PM   #4
Unregistered
Guest
Trade:
Posts: n/a
i mean why do i have to remove it, if i can place laminate’s underlayment on the top of it?
Old 10-11-2004, 04:31 PM   #5
Unregistered
Guest
Trade:
Posts: n/a
Originally Posted by Mike Costello
Remove he pad!!
Thank you, Mike
But why do i have to remove it, if i can place laminate’s underlayment on the top of it?
Thanks again.
Old 10-11-2004, 05:18 PM   #6
Trade: Flooring
You will void the warantee of your laminate ,first and foremost.
That is way too much cusion under a laminate floor it will be flexing and popping every time you walk on it,and eventually your edges of your planks will start to chip from all the movement.
Old 10-11-2004, 06:08 PM   #7
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Total destruction if installed on carpet padding. very very soon after install. Maybe in minutes!
Floorwizard is offline   Reply With Quote
Old 10-11-2004, 06:56 PM   #8
Teetorbilt's Avatar
Like Mike and Flor said, self destruct.
Teetorbilt is offline   Reply With Quote
Remove Deck Boards Tool Joe Wood Decks & Fencing 6 06-24-2007 10:55 AM
How to remove Ice and Water Shield? 3in12 Roofing 20 05-06-2007 12:16 PM
I goofed- how do I remove solder from wall panels? Dustball Plumbing 12 05-04-2007 09:40 AM
2000 sf of ceiling...how to remove insulation? carlspackler Remodeling 8 11-26-2006 11:01 AM
How do I remove and preserve a section of drywall? gschwoyer Drywall 5 12-16-2005 10:16 PM
