Mold Remediation On OSB Subfloor
Old 06-11-2005, 12:47 PM   #1
eddiemac's Avatar
My sister in law is looking at a townhouse that had some water damage. I went to look it over. It appears to be solid structurally, but there is another issue. The inspection indicated mildew, but when I pulled back some water-stained carpeting, I found mold. It was near at the far end of the water-stained area, but it appeared that it was surface mold. We have already determined that much of the drywall will need to be replaced, and have figured that into her offer price.
She wants to put a floating (Pergo-style) floor in on part of the floor, and perhaps re-carpet the rest.
The subfloor is OSB. Assuming that the mold is surface only, my plan is to wash with a bleach solution, then apply a coat of a mold inhibiting paint after it dries. Is this the best plan, or do I want to pull out the subloor and start again?
eddiemac is offline
Old 06-11-2005, 09:19 PM   #2
Teetorbilt's Avatar
Re: Mold Remediation On OSB Subfloor
If the OSB is not distorted (swollen), you have a plan. Make sure that it is absolutly dry and use a penetrating sealer before doing anything on top of it.
If there is any doubt, replace.
Albert Einstein
Teetorbilt is offline
Old 05-26-2009, 01:29 AM   #3
Barkri12's Avatar
Trade: waterproofing
Post
I proposed removal of mold contamination from the framing surfaces using the Armex Accustrip system. This method entails a high-pressure compressed-air spray (consisting of a hopper holding the baking soda and a handheld gun for precision) using a baking soda abrasive.
Barkri12 is offline
Possible Black Mold between 1st and 2nd floor TurnkeyConst Remodeling 10 04-25-2007 11:37 PM
New Construction Showing Mold... thepawnshop Construction 13 10-20-2006 07:43 PM
When you find mold?? theworx General Discussion 2 03-05-2006 03:15 PM
old mold in attic,need advice NHCharger General Discussion 10 10-25-2005 01:00 AM
