Trade: Handyman
Moisture Trap Under Water Base Poly
After 3rd coat of water base poly I got some milky spots on my floors. I stained my floors 3 times, waited a day or 2 to dry, then I applied wbp(from zinsser, not bulls eye)
It says on the can I can apply poly directly on stain without any sealer. After 2 coats of poly floors looked beautiful, after 3d got some milky spots, foggy. Usually it happens rear, only 1 spot in a whole house, and 1 more coat would make it disappear, but it didn't happens this time. I tried denatured alcohol (customer service told me to try it) and it didn't work =( I tried also goof off and some spots got better. Anybody can help ? |
Trade: hardwood floor contractor 28 yrs.
Re: Moisture Trap Under Water Base Poly
You stained the floor 3 times!!!...WTF..WHY?
Trade: Handyman
I used ebony stain to get darker.
Re: Moisture Trap Under Water Base Poly |
ian @antex western
Trade: flooring
without seeing the floor, my guess is that with all the coats you have applied not all the coats have dried out, as a general rule the more coats you put on the longer you have to leave things to dry between coats,
each coat acts a little bit like a sealer to the wood floor, this reduces the absorbtion rate of the wood floor as each coat is applied, so things may be touch dry, but just under the surface moisture can still lurk, you may have to re-sand and start again
#6 | |
Knowledge Factory
Re: Moisture Trap Under Water Base PolyQuote:
Stain is applied and then buffed off. It is not applied and allowed to dry. One coat of stain is about as dark as it is going to get. The second coat does not make it any darker, if your applying and buffing off as your suppose to do. If your painting on stain, 3 coats, I can clearly see the adhesion concerns. Either way, at this point, it is time to sand back to bare wood and start the learning curve, a little farther around the corner.
| Wanting hot water fast... | orson | Plumbing | 12 | 02-08-2009 10:49 AM |
| Blocking up a garage door and water | bert0168 | Masonry | 5 | 02-01-2009 11:04 PM |
| instant hot water | mowpar | Plumbing | 6 | 03-23-2008 10:56 PM |
| Water Heater and well water question | silvertree | Carpentry Picture Post | 0 | 03-14-2008 09:16 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
