Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 09-06-2006, 06:48 AM   #1
Trade: builder
mike webster with a flooring Q
hi im Mike from Glossop,England.
Got a problem with some solid oak flooring thats lifted due to damp.
Is there any way to refix after floor has dried.Would appreciate any
input.Floor has buckled in the middle of the room didnt want to take
it all up.Its been put down over pine floor boards and has a large 4ft
high floor space below.
Owner has been using steamcleaner on it?
mike webster is offline   Reply With Quote
Old 09-06-2006, 07:18 AM   #2
I can answer that right here, and give you a great price....
http://www.contractortalk.com/f11/price-your-project-here-honest-prices-given-12353/
Peladu is offline   Reply With Quote
Old 09-06-2006, 04:08 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Hi Mike from Glossop
I'm going top move this to flooring so maybe you'll get some input
Welcome to the site
Signature Quote
slickshift is offline   Reply With Quote
Old 09-07-2006, 03:34 AM   #4
Trade: builder
Thanks for the offer but i think once you get passed a few thousand miles traveling time can get abit expensive.Cheers mike webster
Old 09-07-2006, 05:51 AM   #5
Get the board stretcher!
TonyD's Avatar
Trade: Residential Building and Remodeling
Mike, Do you mean the grain has lifted? If so then a serious sanding job is in order...Maybe. As with all floor sanding job give NO guarantee. If whole boards are lifted then a replacement is your answer. To the degree of replacement, I'm sure a competant contractor can determine.
"...You cannot strengthen the weak by weakening the strong..."
Abraham Lincoln
TonyD is offline   Reply With Quote
Old 09-07-2006, 10:15 PM   #6
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Generally speaking, the floor should lay back down in time. Most flooring guys would want to wait at least 3 months before sanding it.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline   Reply With Quote
Old 09-10-2006, 12:16 AM   #7
FLOORING GURU's Avatar
Trade: Flooring
It will be fine depending on the amount of moisture in was subjected to. I just repaired and refinished a hallway where a 5 gallon jug of water leaked and sat for half a day. The boards seperated a little and buckled as you had said about your floor. I just replaced the damaged boards with the same species of wood and refinished the whole floor. It worked great and the customer was really happy, Im not a refinish guy so I can't tell you exactly what grit paper or disc youll need. Its really not that big a deal, maybe 4 hours sanding and 2 hours over two days with your poly.
Hey since we are on the subject on refinishing, what are the going rates for a general refinish job per square foot? I charge 2.25 per sq but theres alot of hacks here that are charging 1.50??!!
FLOORING GURU is offline   Reply With Quote
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 12:41 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Hardwood Flooring For Large Projects StonewoodSP Marketing & Sales 1 12-08-2005 09:38 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-27-2004 11:06 PM
