Mesh Mortar Alternative?
Old 03-07-2009, 04:41 PM   #1
Home Work Pro's Avatar
Hello all,
I've always prepared my floors for ceramic and stone installs by increasing the subfloor thickness to 1.25" and then installing mesh and mortar as my base. This has never failed me and I would rather work with the mesh than durarock or similar cement based board.
I'm wondering if there are other methods that would give me the same strength of base but less build-up?
Thanks
Home Work Pro is offline
Old 03-07-2009, 05:28 PM   #2
Mellison's Avatar
Trade: Home Improvement General Contractor
Re: Mesh Mortar Alternative?
Check this out. I have not used it yet and would be very interested to hear from those who have:http://www.schluter.com/6_1_ditra.aspx
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 03-07-2009, 06:09 PM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Ditra would be the best choice imo. You can also use 1/4" cbu, but the Ditra will do eveything the cbu will do and then some, and it's installed height is about an 1/8". If you Kerdi band the seams it is a water proof install as well.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
Mellison (03-07-2009)
Old 03-07-2009, 06:16 PM   #4
R&D Tile's Avatar
Trade: Tile installations
Originally Posted by Home Work Pro View Post
Hello all,
Thanks
Are you saying you build it up 1.25" with plywood, THEN mesh and mortar, how thick is this mesh & mortar bed, If a scratch coat, no good, that has a HIGH failure rate and shouldn't be used.
Either do a full mud job 1 1/4" of mud over tar paper and wire lath or use Ditra, only 2 ways I'll cover a floor now.
R&D Tile is offline
Old 03-08-2009, 01:49 PM   #5
bathroom guru
jarvis design's Avatar
I did wire lath / scratch coat for probably 10-12 years before switching to Concrete board. I now use mostly Ditra, however, you must make sure the floor is strong enough before installing it. While Schluter says you can install directly over 5/8" subfloor, that subfloor must be solid and conform to L/360 (or stronger if using stone). While every job is different, I will normally install 3/8"/1/2"/5/8" plywood, then ditra.
One other option (depending on height requirements) is to use Ditra XL.
I will admit I haven't used it (yet), but would not hesitate.
The other thing I have learned is that Ditra (like a lot of other products) is only as good as the installation. Their installation handbook gives a lot of good information.
Mike Jarvis
P.S. - its nice to see contractors who want to learn and improve!! -
The old adage of "you can't teach an old dog new tricks" only applies to those who have closed minds!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
The Following 2 Users Say Thank You to jarvis design For This Useful Post:
Home Work Pro (03-09-2009), Mellison (03-08-2009)
Old 03-08-2009, 01:54 PM   #6
Mellison's Avatar
Mike Jarvis
Jarvis,
are you saying that the deflection of the floor or substrate is still as much of an issue than when not using Ditra. I assumed this product removed the deflection issue completely.
Please advise as I usually use a Hardibacker substrate when not sure so this would save alot of time.
Mike
Mellison is offline
Old 03-08-2009, 10:17 PM   #7
Knowledge Factory
Floordude's Avatar
Originally Posted by Mellison View Post
Jarvis,
Mike
Is this a trick question????
Deflection ratings must be met before any uncoupling membrane or panel is used.
http://www.AustinFloorguy.com
Floordude is offline
Old 03-08-2009, 10:47 PM   #8
Mellison's Avatar
Not a trick queastion at all Floordude.
One purpose for a uncoupling membrane is to minimize the effects of floor deflection.
I have always installed 1/2 " Hardibacker as an uncoupling agent when a lath and cement base was not applicable.
Has anyone used only the Ditra membrane system directly over a substrate unsuitable for tile installation instead of a build up or cement base? I believe this is what Schluter claims it can be used for.
Mellison is offline
Old 03-09-2009, 12:25 AM   #9
bathroom guru
The deflection has to meet requirements before installation of ditra or hardi backer or concrete board. Plywood is about the only material that can be installed that will actually strengthen the floor, however, plywood sucks as a base for tile.
Now, that being said, I have been told that if you use ditra XL which is just shy of 1/2" you can install it on 5/8" plywood on 24" centers, which, as far as I know, would not conform to L/360. As I understand it, the thickness of the concrete will add the necessary "strength" required without the addition of any other plywood.
If your substrate is OSB, I feel you definately need to add a layer of plywood and then ditra.
And just to clear up one thing, hardi-backer is really not considered an uncoupling membrane - it is a "direct bond" material. Definately better than plywood!! - never used it myself, always used concrete board.
I can honestly say I have had only a couple of floor issues in the last 20 years - one was a cracked floor joist and the other was floor joist that had been shimmed up and when we did the floor the shims fell out!
I still think concrete board gives a good base (if done properly - set in thinset and screwed like hell!), but I like the extra features and benefits of ditra.
519-495-4062
Old 03-09-2009, 06:51 AM   #10
Jarvis, I've read all the literature on the ditra and from what their saying, I should be able to install it over 5/8 t+g subfloor. The cost is not the issue so much as the height. The kitchen I will be starting to demo next week currently has ceramic and the adjacent family room will get new carpet. The subfloor is 3/4 ply over 16oc 2x10, but I'm not sure if the plywood is t+g. If it is, the ditra should work by itself without the build up problem. If the ply isn't t+g then will I need to build up the subfloor with 1/2" ply and then install the ditra?
I normally would just shim the carpet , but there is another transition back to a marble entry at the corner by the kitchen
Old 03-09-2009, 08:46 AM   #11
R&D Tile's Avatar
You are all missing the real issue here, Plywood only strengthens the floor between the joists, it does nothing as far as meeting the L/360 for ceramic and L/720 for stone.
The joist system is what tells you whether the flex in the floor meets specs.
One layer of plywood over any spaced joists is risky, don't care what they say, if you want a good floor to tile and the joists meet specs, 1/2" or better ply over 3/4 or 5/8" is the way to go, THEN a membrane or a CBU.
Unless you are doing a full mud job over a single layer floor, no scratch coats.
I would never install tile over a single wood layer floor on 24" joist spacing.
Ditra and CBUs add no strength to a subfloor, they are only there as a backer for tile or stone.
R&D Tile is offline
Old 03-09-2009, 11:22 AM   #12
bathroom guru
I agree with most of what you said, although, I am questioning the additional layer of plywood not adding strength.
Heres the dilemma, houses are (at least here in Canada) built with an engineered framing structure that "should" create a floor that conforms to L/360 deflection. That being said, I am sure you have been in houses new and old that were on both ends of the spectrum, some floors are solid, others you can feel the "bounce" when you walk across.
I have seen so many failed installations, the overwhelming majority of which were installed on 2 layers of plywood. Our "code" up here for plywood is 2 layers of 5/8". I wouldn't dream of tiling on that!
What really bothers me are the installers that Really don't have a clue, installing 1/4" mahogany over an existing vinyl floor, using 3/8" plywood over the sub-floor, all while using the cheapest thinsets and grouts available.
519-495-4062
Old 03-09-2009, 02:27 PM   #13
Jarvis,
Mike
You assumed incorrectly. Get yerself over to Schluter's site and do some diggin. After that order you a TCNA handbook. Thirdly go dig around over at JohnBridge.com
All the info is out there and easily acessable.
Then go have a beer
Precision Flooring
(772) 237-9900
Old 03-09-2009, 03:04 PM   #14
R&D Tile's Avatar
You're still not getting it.
I said the plywood only adds strength to the flex BETWEEN the joists, adding plywood will not add strength to the joist system, if the joists don't meet L/360 for ceramic, plywood won't solve this, capeesh?
You will have to sister the joists or add a cross beam to cut the unsupported span down to get the flex out if needed.
I would with a membrane or CBU over that and joists being fine, that shouldn't be an issue.
R&D Tile is offline
Old 03-09-2009, 04:12 PM   #15
Mellison's Avatar
Then go have a beer
Thank you precision,
I was finally able to download the Ditra handbook.
And they make it quite clear.
Thanks again.
Mellison is offline
Old 03-09-2009, 10:52 PM   #16
No sweat, 'tis what we're here for right? Pay it forward ya know.
The Ditra handbook is great, I keep a copy on the dash of the truck for reference....I've used it more than I thought I would.
Precision Flooring
(772) 237-9900
Clean mortar off of Glass block??? Nobreus Masonry 21 09-11-2009 07:59 PM
1st Row of Bricks on Lentil Dry, In Mortar, or Either? TomBrooklyn Masonry 16 08-30-2008 04:01 PM
Windows Live Mesh asnider Technology 2 08-29-2008 04:07 AM
Should I Demo Up The Existing Mortar Bed For New Marble? bluethumbnail Ceramic & Stone Tile 3 01-14-2008 08:12 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
