Measure And Cut Oddly Shaped Hexagon Subfloorig
Old 11-04-2017, 03:51 AM   #1
RookiePlumber's Avatar
Trade: HVAC install and repair
Rewards Points: 214
Ripped out a lead pan shower today only to find 4Ē red oak hardwood flooring below.
I need to cut the oak and possibly the subfloor below out to replace the plumbing.
How do I measure those angles? What tool should I get?
Or do you put a piece of cardboard in there and trim until you get the best shape possible. Then use the cardboard as a template?
Also will a 4 x 6 sheet of plywood be adequate to fill that space? I canít get a 4x 8 into the elevator.
RookiePlumber is online now
Old 11-04-2017, 09:14 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,701
Re: Measure And Cut Oddly Shaped Hexagon Subfloorig
You can make a template by taping poster board together. Don't skimp on the tape.
Or put a piece down and use it as a template for a rectangular cut.
MarkJames is online now
RookiePlumber (11-04-2017)
Old 11-04-2017, 09:29 AM   #3
tjbnwi's Avatar
Rewards Points: 1,126
Use drywall shim and glue gun to make the template.
Drywall shim glued together to make templates, one of the tops from template.
Measure and cut oddly shaped hexagon subfloorig-img_1168.jpg   Measure and cut oddly shaped hexagon subfloorig-img_1171.jpg   Measure and cut oddly shaped hexagon subfloorig-img_1306-2-.jpg
tjbnwi is online now
The Following 4 Users Say Thank You to tjbnwi For This Useful Post:
FrankSmith (11-05-2017), overanalyze (11-05-2017), RookiePlumber (11-04-2017), VinylHanger (11-05-2017)
Old 11-04-2017, 09:34 AM   #4
MarkJames's Avatar
I thought plumbers just closed their eyes and cut wherever and however.
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
nesc39 (12-03-2017), RookiePlumber (11-04-2017)
Old 11-04-2017, 09:48 AM   #5
tjbnwi's Avatar
As his (I assume it's a he) name implies--he's still a rookie. Hasn't learned the wayward ways yet.
MarkJames (11-04-2017), RookiePlumber (11-04-2017)
Old 11-05-2017, 02:20 PM   #6
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
What where those templates for Tom?
"Nobody is more inferior than those who insist on being equal" -Friedrich Nietzsche
Krok is offline
Old 11-05-2017, 03:21 PM   #7
tjbnwi's Avatar
Counter tops. The time frame did not allow for the cabinets to be set, then templated. The GC knew he was responsible if the tops did not fit.
The tops all fit with very minor tweaking.
Old 11-05-2017, 04:28 PM   #8
Rewards Points: 214
I created a template using wax paper. Doubt itíll hold when I move it. But it took literally 5 minutes.
Iím gonna pick up some drywall shims tomorrow and create a template. Local Home Depot and Loweís doesnít carry them. Maybe a lumber yard.
Iíll use a staple gun to secure them.
Great idea!
Old 11-05-2017, 05:05 PM   #9
Big Shoe's Avatar
Rewards Points: 1,716
Toms pictures are Luan cut into 2Ēstrips. Thatís what we use for templates. Hot glue together.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
overanalyze (11-06-2017), pinwheel (11-12-2017)
Old 11-05-2017, 08:35 PM   #10
tjbnwi's Avatar
They're drywall shim. Come pre cut 1.5"x3'.
https://www.menards.com/main/buildin...55.htm?tptm=pf
Big Shoe (11-06-2017), overanalyze (11-06-2017)
Old 11-05-2017, 08:37 PM   #11
tjbnwi's Avatar
Great idea!
If you have a Menards near you they stock them.
Old 11-05-2017, 08:38 PM   #12
Krok's Avatar
Rewards Points: 844
That's what I figured Tom, but wasn't sure.
rookieplumber,
I don't think you know what you are doing and when I tried to find your 'help me' subject on where you f/u the shower that was moved, I looked into your posting history to find it and all of your posts were "how do I?" posts on bathroom remodeling.
Have all these been for relatives/girlfriends or were they for others?
Who is this one for? Are you an apprentice? What year? Was a permit pulled? Why isn't someone else doing the carpentry?
Forgive me but there is a lot of fraud in the trades, both on people that try to pass as 'contractors' and people that are homeowners/businesses that defraud legitimate contractors, so speaking for myself, I can be a bit jaded.
Krok is offline
Old 11-05-2017, 08:44 PM   #13
FrankSmith's Avatar
Rewards Points: 4,134
I created a template using wax paper. Doubt it’ll hold when I move it. But it took literally 5 minutes.
I’m gonna pick up some drywall shims tomorrow and create a template. Local Home Depot and Lowe’s doesn’t carry them. Maybe a lumber yard.
I’ll use a staple gun to secure them.
Great idea!
Don't waste to much time on this. Rip some 1/4" plywood to a few inches and make your template. Why staple? Hot glue works so well. No reason to reinvent things that work so well.
An added bonus to a sold impolite. You will know if you can get it in and out.
If you can't. Template again. This time two pieces.
FrankSmith is online now
Old 11-05-2017, 09:24 PM   #14
tjbnwi's Avatar
Hot glue gun, don't use staples, you'll only screw yourself.
Wherever you get the shim should have a decent glue gun.
Old 11-06-2017, 05:51 AM   #15
Big Shoe's Avatar
You should look into ripping your own strips of lauan . We also call them door skins.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
KAP (11-10-2017)
Old 11-06-2017, 07:42 AM   #16
tjbnwi's Avatar
I'm to lazy for that.
The drywall shims cut with scissors, you can fold them on themselves to square ends, cut little pieces glue them on full pieces to follow curves and wall irregularities...
Bummie (11-07-2017), Metro M & L (11-21-2017), RookiePlumber (11-06-2017), slowsol (11-06-2017)
Old 11-09-2017, 09:34 PM   #17
tjbnwi's Avatar
Current jobs templates.
Xtrememtnbiker (11-09-2017)
Old 11-09-2017, 10:45 PM   #18
Krok's Avatar
Rewards Points: 844
No reason for him to template anything. This is really simple stuff, really.
Anywho...to the bigger he could make far more money in his primary trade--hvac--than he could asking for help for his girlfriend's tile wall that he didn't even read the directions for as he tiled it and wasn't level or plumb or someone's shower he did where the glass didn't line up due to the curb and wall or a vent he couldn't figure out for his...IIRC his cousin or something.. Don't know whose medicine chest he screwed up or bathroom vent he couldn't figure out how to put a fan into.....
he just needs to just stay away from all these bathroom remodels for his friends and relatives as he clearly doesn't know what he's doing and.....just do his listed trade...HVAC.
20 years ago in Denver you could make 60K/year and they'd pay your expenses to move you out there. HVAC are dying for people. He's wasting his time.
Tom, you template your work? Who built that ****?
Krok is offline
Old 11-09-2017, 11:05 PM   #19
tjbnwi's Avatar
Those templates will go to a granite fabricator. They're to busy to get to the templating before Thanksgiving.
Built which/what?
RookiePlumber (11-10-2017)
Old 11-10-2017, 06:10 AM   #20
Rewards Points: 214
Krok - These projects are for my own home - not for clients. I am not getting paid to learn on the fly - I just donít have the money to renovate my home. While I donít have the extra money laying around I do have time and I intend to use it productively.
