Luan
Old 01-03-2005, 08:10 PM   #1
GKEYS55's Avatar
Send a message via AIM to GKEYS55
Luan
What is going rate for installing luan? I live in Maryland.
I have a job that is 6300sqft Going tomorrow, and can you give me any pointers on installing it?
GKEYS55 is offline
Old 01-03-2005, 09:47 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Luan
It should be 500 bucks a sheet if your going to be held liable.
especially if vinyl will be installed on it.
if a floating floor is going on it, it may be no big deal.
maybe for that size amount, possibly 25 bucks a sheet?
I live in Alaska so I am pretty clueless for lower 48 prices.
Floorwizard is offline
Old 01-03-2005, 10:01 PM   #3
GKEYS55's Avatar
Re: Luan
VCT is going over it.
GKEYS55 is offline
Old 01-04-2005, 02:40 PM   #4
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Re: Luan
Be sure at the very least that is is an underlayment grade luan . What most dont realize is that there are several grades ,and out of all of them ,very few are underlayment quality. The difference being the glue used to make it.
Your best bet is to use a subfloor that is recommended by the manufacturor of the VCT going in.
That being said, just be sure that the floor your going over has been scraped of all the sheet rock mud and such and swept good.
I use 1 1/4" long 1/4" crown,underlayment staples. Every 4 inches or so in the field and every two inches at the seams. Be sure your compressor is set right so the staples countersink without blowing through. And please pound any in that did not sink!
Keep your seams tight and cut tightly around door casings and showers and the like.
Be sure to use plenty of staples,because to be quite honest ,luan isnt the best underlay for VCT. You dont want it to move or flex at all.
Mike Costello is offline
Old 01-04-2005, 04:37 PM   #5
Flooring Guru
Re: Luan
I would use 1/4 multiply for the least.
5/8 underlay grade plywood is even better.
Old 01-04-2005, 05:46 PM   #6
GKEYS55's Avatar
Re: Luan
Is .40 sqft a good price that's $12.80 a sheet. Installing 1/4inch Luan. Now Im doing the job through a company as a sub. Im installing over 6000sqft.
GKEYS55 is offline
Old 01-04-2005, 11:09 PM   #7
Don Benham's Avatar
Send a message via AIM to Don Benham
Re: Luan
For 1/4 inch underlayment I 4x8 would be about $18/sheet labor. I don't use luaunn anymore though, only 5-ply Birch for my customers. Thats alot of footage you have so good luck getting a fair price as a sub.
Ditto everything Mike said. Luaunn is garbage, even underlayment grade, IMO. But make sure it is at least that good. Watch out for voids. They like to hide.
I wouldn't gaurantee anything over Luaunn.
Good luck,
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline
Hardwood over luan, Go or No Go? sage Flooring 6 03-11-2007 12:42 AM
Tile on hardwood Browny Flooring 25 04-02-2006 11:52 PM
Stapling Luan????? diezeldawg Flooring 10 12-19-2005 10:58 PM
Questions on underlayment for sheet vinyl Lone Wrencher Flooring 8 08-02-2005 12:18 AM
What's a sub-floor? Mike Finley General Discussion 11 03-06-2005 08:49 PM
