custom installations
Trade: Flooring
Loose Vinyl
Heh everyone:
A fellow installer I work with, installed some vinyl over VCT and it came loose in some spots. I was asked to take care of it without cutting it open. Well, I haven't discussed it with the customer yet, but I'm sure she's not going to be happy to see seams she didn't expect. The other night, I came up with the idea of using a spray adhesive, by cutting a slit in the vinyl and spraying it in between the floor and vinyl....any suggestions or comments? Thanks for your help! |
General Contractor
Trade: General Contracting and Painting
Re: Loose Vinyl
In the past we had luck injecting adhesive using a wallpaper paste syringe like this http://www.paintstoreonline.com/cgi-...126&p_catid=27 hope this helps.
Trade: Flooring
Re: Loose Vinyl
Thx for the hint, I do have such a seringe, but the problem is, it has to be almost just a mist of adhesive due to the constricted space between the floor and the vinyl flooring. I'm doing test strips with a spray adhesive I picked up at the hardware store.
Tile Contractor
Trade: Floorcovering
Re: Loose Vinyl
this works some times... but not all the time take a perm marker and write on the unglued spots.... "dont look here" costomers usualy dont look for 1 year and 5 minutes from when you install the job its uncany!
My Father Taught Me How To Survive But My Mother Taught Me How To Live! |
#5 | |
General Contractor
Re: Loose VinylQuote:
Flooring Guru
Trade: Sales Manager
Re: Loose Vinyl
HA HA HA HA
Good one!
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Trade: i am a small remodeling contractor been at this most my life
Re: Loose Vinyl
maybe a lil heat might do it who knows ..
Tile Contractor
Re: Loose Vinyl
yes a bit of heat and your hand roller does the trick in most cases. thats what i seen my father do worked like a charm.
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Loose Vinyl
Inject it with the same adhesive that was used to install it (hopefully a premium sheet goods glue or at least a multi-purpose) heat it, and roll with a hand roller.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| Fiber Cement almost same cost as Vinyl? | MKECONTRACTOR | Windows, Siding and Doors | 17 | 12-20-2008 06:34 PM |
| Scalloped Vinyl | Shamrock | Windows, Siding and Doors | 1 | 09-18-2006 04:20 PM |
| vinyl decking with hot tub | nriddock | Decks & Fencing | 2 | 06-16-2006 02:10 PM |
| Vinyl on vinyl? | reveivl | Flooring | 13 | 12-16-2005 07:00 PM |
