Loose Lay Vinyl ?
Old 12-16-2008, 12:38 AM   #1
MeatBallDryWall's Avatar
Trade: Residential & Commercial Hanger/Finisher
Rewards Points: 75
Loose Lay Vinyl ?
Hi all I have a n00b ? here. I had a guy lay a vinly floor & he just cut it into place & used doublesided tape in 2 places ( the entrance door & LR threshhold) & the rug is bucking up in 3 places. I installed the quater round & it's all that's holding the rug down around the edges. The flooring is a high quality Armstrong floor bought from Slow's. What can I do to stop the bucking of the rug? Thanks in advance for any advice.
MeatBallDryWall is offline
Old 12-16-2008, 05:52 AM   #2
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: Loose Lay Vinyl ?
Is it coming up after moving something heavy across it? usually on a loose lay you can put buckles into it when you move something heavy. If that's not the case, then it's usually cut too tight to the wall and it's buckling where the material expands without an adequate expansion joint. Loose lay is acceptable if this is Armstrong's CushioStep product. However, we never loose lay these types of material. There are almost always issues like this.
gideond is offline
Old 12-16-2008, 06:04 AM   #3
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
I only lay vinyl when there's a gun to my head or am having a low IQ day but when I do I always do a full spread because of exactly what your are describing. That said, even though I do not understand why, qualified flooring professionals still do loose lay installations. I am eager to hear their reasonings as to why.
davitk is offline
Old 12-16-2008, 08:00 AM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,952
Hope this helps.
What you describe is the latest and greatest right from the Armstrong installation pdf....but...?
http://www.contractortalk.com/f10/no-glue-sheet-floor-14649/
We Fix Houses is online now
Old 12-16-2008, 10:02 AM   #5
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
If is is IVC is is perfectly acceptible to loose lay. I have installed many yards with no problems. Your installer got it tight somewhere. You will have to remove the trim, find where it is tight and trim it.http://vinylflooring.org/movie.html
rusty baker is offline
Old 12-16-2008, 11:10 AM   #6
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Rewards Points: 2,000
Welcome the wonderful world of the new Vinyl.
It's completely acceptable if installed correctly.
There are links others that have posted that should clear up a few things.
Floorwizard is offline
Old 12-16-2008, 03:41 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
It is acceptable, but not preferred...imho. With the sf cost on some of these new pvc floors one has to wonder why would you skimp on the install?
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 12-16-2008, 04:56 PM   #8
Flooring Guru
I understand what you are saying. I personally glue all of the glass backed Vinyls down. But I would not consider a glass back Vinyl in a bathroom (skimping) because it is the way to install it. Gluing down in that application would have the same result as if you did not. But in Kitchens where there may be appliances moved across it, then I agree with you completely.
So all in all I would say it depends on the area.
Old 12-17-2008, 05:14 AM   #9
Rewards Points: 75
Thanks for all the advice everyone, I really appreciate it. What does "full spread" mean? Gluing the entire rug? Sorry i'm a drywall contractor, I have no clue about this. Also, nothing heavy has been moved onto or across it. It just started bucking about a week ago. As well as I can recall, the installer cut it fairly tight around the edges. So what do I need to do now to correct this? Hire someone that's worth a ?
Old 12-17-2008, 05:24 AM   #10
Mike Costello's Avatar
Trade: Flooring
Rewards Points: 250
make him come back and make some relief cuts
Mike Costello is offline
Old 12-17-2008, 07:01 AM   #11
davitk's Avatar
Rewards Points: 502
No offense intended, meatball, but check first to see whether you nailed the base shoe into the floor instead of the wall. That shoe (quarter round) is only intended to cover the gap between the flooring and baseboard, while still allowing the floor to expand and contract underneath.
davitk is offline
Old 12-17-2008, 09:40 AM   #12
Rewards Points: 75
No offense intended
OMG, I am so offended! JK, actually I did shoot it into the floor The floor is laid very tight around the outside as well(I removed a couple pieces of QR) So, should I A: get him to make relief cuts. & or B: Shoot the QR into the base. Or C: Both + more? Should this stop the buckling of the rug or should it be 100% glued?
Old 12-17-2008, 12:35 PM   #13
Flooring Installer
Trade: flooring
Rewards Points: 48
Pull the QR and see if there is a gap between the vinyl and wall. Nailing the QR to the floor will make the vinyl buckle, so the installer may have done nothing wrong. If you make him glue it be prepared to spend more money. That adhesive is $40 gallon.
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 05:34 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 06:04 AM
Vinyl Deck, how do they get away with it!? nbishop Decks & Fencing 12 08-18-2008 09:58 AM
Fiberglass vs Vinyl replacmemnt window davinci General Discussion 3 08-12-2008 12:31 AM
loose vinyl Taurus Flooring Flooring 8 06-06-2006 07:51 PM
