Loose Edges Crackin Grout
Old 05-05-2006, 03:19 PM   #1
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
Hello all,i got this tile job i just finished last week well the homeowner called and theres crack in the grout on some the tiles but only on the corners mabe couple inches.i taped on the tile in them spots and sure enough it hollow sounding where its not bonded to the thin set there 12x12 ceramic floor tiles . is there an easy fix or do i gotta take tile out and reset ..also i havnt had this before what do u think i did wrong ..
Blackhawk is offline
Old 05-05-2006, 10:16 PM   #2
Remodeler
lxdollarsxl's Avatar
Trade: Remodeler/Painter
Send a message via Yahoo to lxdollarsxl
Re: Loose Edges Crackin Grout
Maybe you didnt have the thinset spread evenly over the area You may have to remove tiles that are affected and redo them.
lxdollarsxl is offline
Old 05-05-2006, 10:48 PM   #3
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
What type of subfloor was it?
What kind of trowel did you use?
ron schenker is offline
Old 05-06-2006, 12:04 AM   #4
Tileman Rich's Avatar
Trade: Kitchen and Bath Remodeler Tile is our speciality
Send a message via AIM to Tileman Rich Send a message via Yahoo to Tileman Rich
A number of things could of caused the tile to not stick: when you set the tile it did not get full contact with the thin set ( not enough mud under the tile, or you did not press it down hard enough to get it to stick), someone may have stepped on the tile after it was set but before it was dry I could go on and on but this seams to be the leading cause of lose tile.
Yes you are going to have to remove the tile and reset it. Clean the tile if you save it and also clean the thin set out and start over on the tile that are bad and then regrout.
Sorry but I would say all of us have been there done that.
Good luck
Rich
Tileman Rich is offline
Old 06-09-2006, 02:34 AM   #5
415moto's Avatar
Trade: General contractor
^^ like they said. if its hollow, you dont have a solid bond. the tile is large 12x12 its moving under weight when its stepped on or near. the movement is cracking the grout. you use a trowel or spotted it?
remove and reset it.
415moto is offline
Old 06-10-2006, 01:36 AM   #6
Blackhawk's Avatar
well you guys where right someone steped on the tile after i left that nite.i noticed they where the ones that lead to the kitchen sink so i started asking questions and yep them and kds did it..anywy i took a couple up that where bad and reset a few others was just on the corners i dug out the grout and injected epoxy in there and let it flow then regrouted that was last month so far so good i wanted to wait for update to make sure . i wanna thanks you all for the quick help i was so stressed out when i posted over it ..again thank you all for the help...
Porcelain Floor Tile - fixing sanded grout cracks ETHICS05 Flooring 11 07-18-2007 07:43 AM
Grouting over Grout? c5150b Ceramic & Stone Tile 13 05-22-2007 07:44 PM
Grout width query. Nick S. Ceramic & Stone Tile 18 10-12-2006 10:22 PM
best way to seal grout for glass mosaics. ApgarNJ Masonry 2 06-27-2006 06:18 AM
grout against the wall MattCoops Ceramic & Stone Tile 4 04-25-2006 11:48 AM
