Laying Tile In A Walkin Freezer?
Old 09-09-2005, 09:14 AM   #1
CogentRES's Avatar
I have a friend who does commercial remodeling. He does lots of tile work in restaurants. One of his clients approached him about retiling a walkin freezer. Of course he said they could not turn it off.
I realize the inherent problems that seem to make this impossible, but I am not a flooring expert. So I turn to those who are, is there any way to do this?
CogentRES is offline
Old 09-09-2005, 09:42 AM   #2
soxfan's Avatar
Trade: flooring
Re: Laying Tile In A Walkin Freezer?
I was involved in a large mud job when I was a teenager, they did two large coolers with Ceramic, I mostly just lugged and mixed the mud. I'd suspect that any technique that's approved for an outdoor setting in the North would be ok.
soxfan is offline
Old 09-09-2005, 02:23 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Porcelain, Porcelain, Porcelain, Porcelain, Porcelain
and more Porcelain
Floorwizard is offline
Old 09-09-2005, 03:31 PM   #4
CogentRES's Avatar
and more Porcelain
I imagine this should be used with Epoxy, Epoxy, Epoxy?
Would it be possible to work on small sections of the floor each night ( work window is from 3AM to 9AM) and use some sort of heat source to keep the adhesive and grout warm until they set?
I have heard the Laticrete commercial epoxy grout sets within hours if it is warm enough.
I spent some time reading and searching over at the JohnBridge forum. It is excellent but the only thing I found on this subject was that everyone there despises restraunt tile work. (understandably it would seem)
Old 09-09-2005, 05:07 PM   #5
soxfan's Avatar
Trade: flooring
Actually Epoxy only comes in two parts, not three.
soxfan is offline
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Bad tile job AAPaint General Discussion 9 07-26-2006 04:56 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
