Laminate Underlayment - 3in1 Vs 2in1
Old 12-23-2004, 08:10 PM   #1
taboyce106's Avatar
Question
I am planning on installing laminate to replace the carpet in my house. I have the laminate picked out - a Shaw product. There are two different kinds of underlayment: 3 in 1 and 2 in 1. The difference from the description is primarily around a better sound barrier. The 3 in 1 is over twice the price of the 2 in 1. Is the better underlayment worth it? Just curious from others who have experience with this. Thanks
taboyce106 is offline
Old 12-23-2004, 08:26 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Laminate Underlayment - 3in1 Vs 2in1
the sound barrier deals with DBA. so it makes it harder for sound to penetrate.
stereo's, chatter, ect...
if it's going upstairs, it is worth it. but you will still hear people walking around up there, it will just sound more like a dull thud, then a click.
Floorwizard is offline
Old 12-23-2004, 09:00 PM   #3
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Good choice. I actually have Shaw Laminate in my house. Its perfoming great under some pretty heavy use.(two teenagers and two large dogs)
I installed a little over 16 thousand sqaure feet of laminate this year and I agree with what Florcraft says. You cant go wrong with an upgraded underlayment. I used Whisper Walk brand,which sort of looks like the old hair and jute carpet pad,only thinner.But you will get excellent performance from Shaws upgrade as well.It will help cut down greatly on that hollow noise you get when you use a wimpy pad underneath.
Mike Costello is offline
Old 12-24-2004, 02:44 PM   #4
taboyce106's Avatar
I only have a single story house with no basement (on Gulf Coast, just above sea level). Therefore I am not really concerned about noise from one level to another. Is the 3 in 1 underlayment worth the extra dollars? Thanks
Old 12-25-2004, 01:46 AM   #5
Flooring Guru
Well, the only good an upgraded pad will make, is that is will not sound so hollow. If that's your gig, then go for it.
if it doesn't matter, then save the dough.
Old 01-22-2005, 11:07 AM   #6
tuman84's Avatar
I dono guys, the 3-in-1 kind of doesnt make sense to me.
If the plastic is on the top as well, wouldnt that create a pool under the flooring if the user spills a glass of water for example?
tuman84 is offline
Old 01-22-2005, 11:59 AM   #7
Flooring Guru
I would agree that if there is a moisture barrier on top of the pad, it is probably quite useless. But I do not believe this is the case.
I would imagine 3 in 1 means
pad
sound barrier
moisture barrier (on the bottom of the pad)
Old 01-22-2005, 01:52 PM   #8
Teetorbilt's Avatar
taboyce, Think about sealing the slab prior to installing the vapor barrier, I do this anywhere the water table is just a few feet down. Unless specified, I use the 2 in 1, add a second layer of the inexpensive padding for a little more give and insulation.
Scrape and vacuum prior to sealing, the smallest little stone can puncture the vapor barrier.
Teetorbilt is offline
Old 01-26-2005, 06:15 PM   #9
tuman84's Avatar
The 3-in-1 underlayment that i have seen is:
plastic
foam
plastic
And the foam is the sound barrier isnt it?
tuman84 is offline
Old 05-21-2007, 03:24 PM   #10
AffordaFloors's Avatar
Trade: Flooring sales and installation
The 3-in-1 designation means:
1. Underlayment (which dampens the sound of the floor and helps make up for minor subfloor irregularities).
2. Poly moisture barrier
3. Adhesive strip on one side so that side-by-side runs of the underlayment can be attached to each other.
AffordaFloors is offline
Getting laminate under door casing and jambs Blackhawk Flooring 6 01-02-2008 04:14 PM
Laminate Floor Richard Flooring 15 12-22-2006 12:59 PM
condo laminate flooring, underlayment necessary? involution Flooring 5 12-08-2005 03:58 PM
Laminate? Underlayment? Bathrooms? OneLionessa Flooring 3 09-12-2005 09:37 PM
laminate underlayment help ottohomes Flooring 2 11-24-2004 08:48 PM
