Trade: Floorist
Laminate, Interior Climate Affect On
I was contacted by a consumer who lives near Sacramento, California, with the following (summarized) inquiry:
"I have a couple of quick questions about the Harmonics [laminate] flooring ... the main room it will be in is heated with a wood stove and I am concerned about the 50% humidity instructions. Have you had any experience with that as a problem? I know that the wood stove heat drys out everything in the house..." I replied with the following: "Trouble will arise if your home's temperature and humidity covers a broad range throughout the year. Follow the manufacturer's guidelines as close as possible. If you are likely to experience a great deal of humidity followed by extreme drying, you will likely find your floor reacting adversely. The best way to avoid trouble is to acclimate as instructed before installation, leave PLENTY of expansion space, and use T-moldings at the doorways to allow rooms to shrink/ grow seperately." What do you all think? How would you have replied?
• • • Greatness is a result of focused, deliberate practice • • • Last edited by TopFloor; 09-13-2009 at 07:32 PM. Reason: No replies |
egotistical prick
Trade: Wood Inlay
Re: Laminate, Interior Climate Affect On
I don't do laminates but why the worry over shrinkage with laminate? Thought this was a non-issue?
#3 | |
Knowledge Factory
Re: Laminate, Interior Climate Affect OnQuote:
No, it will shrink. End gaps, and pulling out from under trim, as it contracts. They need a humidifier going in the winters, or keep pots of water boiling on the stove, like granny use to do.
| The Following User Says Thank You to Floordude For This Useful Post: | TopFloor (09-15-2009) |
Flooring Guru
Trade: Sales Manager
plus it's HARMONICS
it's gonna need all the help it can get!
------------------------ "in 20 years you will regret more what you did not do than what you did" |
| Tags |
laminate climate ![]() |
| Laminate Floor Install Tips | jakejorgenson | Flooring | 21 | 07-18-2009 09:49 AM |
| best blade for cutting laminate | platinumLLC | Flooring | 12 | 05-07-2009 11:12 PM |
| stress crack in laminate top | rockingjwolf | Construction | 10 | 03-12-2009 08:30 PM |
| What to charge to pull up 325sqf of Laminate flooring?? | TileMan77 | Flooring | 3 | 07-17-2008 08:57 PM |
