Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-15-2006, 10:26 PM   #1
mpohl77's Avatar
Trade: Flooring (Laminate, Tiles)
Laminate Flooring pricing
What is the going rate per square foot for labor for laminate flooring in the Atlanta area?
Thanks,
Michael
mpohl77 is offline   Reply With Quote
Old 02-18-2006, 12:09 PM   #2
Trade: Consultant
Michael-
What's the difference what the "going rate" is? The only rate that should matter to you is whatever your hourly rate is, divided by the number of SF you can install in an hour. If everyone else charges less than that, and you decide to do the same, you're selling yourself short. If your rate is too high for the area, you either need to be able to sell yourself to justify the higher cost, or you need to be able to lower your cost somehow (perhaps becoming more efficient).
Bob
Bob Kovacs is offline   Reply With Quote
Old 02-18-2006, 03:20 PM   #3
Trade: Flooring Installation
I charge $2.50 a sq ft here in VA and buy the flooring for about .75-2.00 depending on what kind cust wants.
RichSmith1 is offline   Reply With Quote
Old 02-18-2006, 11:04 PM   #4
Teetorbilt's Avatar
I get a touch more here, $3.75. Much depends on what else you offer. I always try to sell an upgraded base as opposed to the 'dreaded 1/4 round'.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
What Blade do you use for Laminate Flooring? dayspring Tools & Equipment 8 01-21-2007 02:04 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
laminate flooring boman47k Flooring 6 12-04-2006 06:06 AM
