Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 06-03-2008, 02:18 AM   #1
Trade: General Contracting
Laminate Flooring.. Glue or Nail?
When installing laminate flooring i usually just use the flooring glue they sell at the depot... i had one guy tell me to use a finish nailer and nail it down instead (subfloor is 3/4 ply)... i had another guy told me to not use glue or nails.. he said because it expands he uses nothing... just lay it wall to wall and molding around your edges... thoughts????
nick114920 is offline   Reply With Quote
Old 06-03-2008, 02:32 AM   #2
Trade: home improvements and renovations
best to follow the manufacturers instructions
Stewy is offline   Reply With Quote
Old 06-03-2008, 10:14 AM   #3
davy crockett's Avatar
Laminate as in laminate or laminated wood as in real veneer? Is it going to float or not? Floating laminate floors are not glued or nailed to sub, only glued together and that is getting scarce.Manufacturer wil want you to do it his way to avoid warranty issues.
davy crockett is offline   Reply With Quote
Old 06-03-2008, 01:01 PM   #4
Nick
most laminate floors i only use Elmers wood glue so my joints wont seperate, but it not necesary. By default allways go by manufacturers specs. I have never seen nails in the specs by the BTW. It will ruin the product unless you are talking about engineered hardwood which is crp.
pscinteriors is offline   Reply With Quote
Old 06-04-2008, 09:22 PM   #5
Carpenter/fencing
nywoodwizard's Avatar
I don't know of any laminate floor that gets glued or nailed down, maybe the joints get glued on some, like the old pergo. its a floating floor, its suppose to move. And it had better have the required expansion space along the wall edges.
I think your friend was spotted recently.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline   Reply With Quote
Old 06-04-2008, 09:24 PM   #6
AtlanticWBConst's Avatar
As stated: Follow the specific Flooring manufacturer's instructions. If you don't, you may end up voiding the warranty, that the client is assuming is enforce....
- Build Well -
AtlanticWBConst is offline   Reply With Quote
Laminate Floor Glue Removal EMR General Discussion 7 10-14-2008 12:41 AM
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
What Blade do you use for Laminate Flooring? dayspring Tools & Equipment 8 01-21-2007 02:04 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
