Trade: owner/operator
Laminate Flooring Before Cabinets?
anyone installed laminate flooring before installing kitchen cabinets? pro's and con's?
timan
Trade: gen contractor. college instructor construction
Re: Laminate Flooring Before Cabinets?
to save a buck you can mark your cabinet layout, lay flooring and inch or so past and install flooring where the dishwasher will be then use osb or plywood to fill in the area... total time for the job will be less since you don't have to be so precise for your cut off since it will be under the cabinets. also you won't have to trim to get a dishwasher to slide under the countertop stile... we lay under cabinets for tile , real 3/4 wood and particle board for a vinyl floor. If you have other sub's coming in you have to make sure to protect the new flooring and back charge anyone who damages it.
| The Following User Says Thank You to oldtiman For This Useful Post: | jimmyofc (05-31-2009) |
#3 | |
Trade: GC/Remodeling
Re: Laminate Flooring Before Cabinets?Quote:
Con's... probably
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
| The Following User Says Thank You to TimelessQuality For This Useful Post: | jimmyofc (05-31-2009) |
Depending on the layout of the room, setting the cabinets down on it is going to prohibit contraction and expansion and could create buckling in the floor.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
| The Following User Says Thank You to jaros bros. For This Useful Post: | jimmyofc (05-31-2009) |
I have never loved the idea of laminate under cabs.
Lots of weight, lots of plumbing and potential to come in contact with moisture, much harder to fix the floor (disassemble for plank replacement) and of course the potential to pinch the floor somewhere and have expansion issues. It is easier to install though. |
| The Following User Says Thank You to Mike Costello For This Useful Post: | jimmyofc (05-31-2009) |
DavidC
Excellent answer!
The floor is supposed to float, pinning it down with cabinets is not a good idea in my book. I would maybe try Oldtinman's idea at least once to see if it saved any time but would layout carefully so the flooring does not go under the cabs. Good Luck Dave
www.CookContractingLLC.com |
| The Following User Says Thank You to DavidC For This Useful Post: | jimmyofc (05-31-2009) |
The Deck Guy
Counterpoint:
Yes, cabinets are heavy on top of the floor, but how heavy is big armoire full of clothes, or a piano, or a big bookcase? All of those items are heavy too and no one gives a second thought about putting them over laminate, right? Food for thought....
| The Following User Says Thank You to Greg Di For This Useful Post: | jimmyofc (05-31-2009) |
#8 | |
DavidC
I think the best real answer is to try and talk them out it when they want laminate in kitchens and baths, have a waiver ready for the ones that won't listen. Good Luck Dave
#9 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
| The Following User Says Thank You to PrecisionFloors For This Useful Post: | jimmyofc (05-31-2009) |
Trade: Flooring Professional
Laminate under Cabinets.....NO
| The Following User Says Thank You to Rkeister For This Useful Post: | jimmyofc (05-31-2009) |
Trade: Floorist
...what about caminate over labinates?
![]() Seriously, though, PrecisionFloors said it perfectly (again): |
| The Following User Says Thank You to TopFloor For This Useful Post: | jimmyofc (05-31-2009) |
In new construcion homes we used to install the floor first for speed in application.
When we set the cabinets, we would just mark the floor around the base cabinets and cut the floor in place leaving the under cabinet flooring in place. Works like a charm and most times the toe kick covers the cut. Scribe works as a shoe on the exposed ends |
thanks for the advice will stick with my gut and layout cabinets and install 3/8 ply where cabinets go thus cabinets will be above flooring and let the floor do what it's suppose to do float. thanks for the input guys
Knowledge Factory
It is when you have very heavy stuff opposite each other across the room.
A wall of loaded bookshelves and across from it, a piano. Or in a kitchen, you have loaded cabinets, and across from it, sits the fridge, or more loaded cabinets.
| laminate flooring placement | nwksremodeler | Flooring | 7 | 06-19-2009 10:24 AM |
| Laminate flooring lifting up. | combuilder | Flooring | 5 | 02-18-2009 08:14 AM |
| What to charge to pull up 325sqf of Laminate flooring?? | TileMan77 | Flooring | 3 | 07-17-2008 08:57 PM |
| Cabinets on top of laminate flooring | Blackhawk | Flooring | 24 | 08-30-2006 01:23 AM |
