Laminate Flooring Around Metal Door Bucks ?
Old 05-30-2012, 04:21 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,952
Looked at a job today. Its a small machine shop factory with offices up front.
The existing floor is 5/8 engineered about 12 - 15 years old. It is beat up pretty good as expected. Its caulked around the bucks.
The owner wants to go with laminate over the eng floor. I can do it....yes.
What if any suggestions for around the door bucks ??
Unlike eng floor, Lam is spongy - so any advice around the door bucks ? There has to be some installs around with this challenge.
Further, there's existing cove base. Its 5 offices and a common hallway. I told them I believe BB and shoe would be needed. However I'm tempted to quote going back with cove base. I believe I can cover the gap as cove will go about 9/16 off the wall. I'll have to cut the lam a bit closer than usual.
The budget is pretty tight as he said cheap, cheap - a few times for the flooring.....Understandably - its a machine shop. I'm adding an addl office too in the plant. Its all for the ladies up front.
So what about cove base on the lam and doing around the door bucks ??
Thanks for this input.
We Fix Houses is offline
Old 05-30-2012, 06:34 PM   #2
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Re: Laminate Flooring Around Metal Door Bucks ?
Door jams?
Groutface is offline
Old 05-30-2012, 08:21 PM   #3
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,316
If it's engineered is it refinishable? That would save some money...
Metro M & L is online now
Old 06-01-2012, 03:01 PM   #4
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Personally I would attempt to steer them toward an Lvt product instead. It's thinner, better suited for the type of traffic they will see, and well stand up to the moisture a commercial cleaning crew will no doubt put on the floor. Laminate has it's place but imho a machine shop ain't one of them.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 06-01-2012, 08:13 PM   #5
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
Put a ferrous blade in your jambsaw?
smeagol is offline
Old 06-04-2012, 02:57 PM   #6
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 590
We recently did a commercial space like this. We just cut as close as we could to the door jambs and found a caulk that was almost an exact match to the dark gray jambs. It turned out looking really good.
RhodesHardwood is offline
Old 06-05-2012, 01:36 PM   #7
ernesto's Avatar
Trade: Licensed Contractor in AZ
Rewards Points: 150
Don't do that as you could cause a fire, theres wood behind there. Plus, some building codes to not allow you do cut them. I'd leave a gap, stuff with cork or some silicone that does not set hard. Some hard set caulk can stop expansion and lock in the floor.
Heck it is a machine shop, just leave a gap....
Top Floor Installation Co.
Tucson AZ
www.tucsonazflooring.com
http://www.floorsavior.com
ernesto is offline
Old 06-11-2012, 06:32 PM   #8
AustinDB's Avatar
Rewards Points: 592
how about the vinyl plank looking flooring. I would be nervous of the laminate 'floating' from one side to the other. That is, if you have a 1/4" gap on each side of the hall, what's to stop it from pushing all the way to one side and leaving a 1/2" gap-all it takes is enough sideways pressure, say from guys horsing around in the halls. The vinyl planking would be glued down=no movement and not as noisy as the laminate.
AustinDB is offline
Old 06-11-2012, 06:39 PM   #9
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,432
as spoksman for the non ferreus door jamb manufactures i stongly dissagree wih post #5, we have spent many hours in dc pointing out the many benifits of non ferreus jambs.
sunkist is offline
Old 06-11-2012, 06:51 PM   #10
slowsol's Avatar
Rewards Points: 2,212
a spoksman huh?
I guess they didn't have a spelling section on the application.
-John
slowsol is online now
Old 06-11-2012, 06:59 PM   #11
Thanks for the replies fellas. The lam cut away from the jambs would be ok with them I'm sure. Not for me really...? A comm vinyl product would have been better but they wanted wood. I didn't have time to source the best alternatives.
Wasn't a good fit so I let it go. Not a referral but a lead from an ad.
Old 06-11-2012, 09:06 PM   #12
AustinDB's Avatar
Rewards Points: 592
you're not installing 'wood'
AustinDB is offline
Old 06-11-2012, 09:12 PM   #13
photograph of wood - sorry
The Following User Says Thank You to We Fix Houses For This Useful Post:
AustinDB (06-12-2012)
Old 06-21-2012, 03:28 PM   #14
239STAIRS's Avatar
Trade: STATE LICENSED GENERAL CONTRACTOR
Rewards Points: 75
Sounds like a pretty simple job. I would just run the floating floor directly on top of the existing floor (provided no structural or water damage) throw some 6mil poly down and haul ballz. As far a movement thats not a concern(72chevy4x4)usually this would only apply to stairs. When cutting around door give the wood a back bevel to allow the face fit closer to jam. Them just cut tight and show those skills
Atlantic Construction & Design LLC Ft Myers, FL
239STAIRS is offline
metal studs and 7 1/4 oak flooring mikeybobo Contractor Swap 1 10-16-2010 07:20 AM
Laminate flooring lifting up. combuilder Flooring 5 02-18-2009 07:14 AM
Metal roof question Burby Roofing 11 01-22-2009 12:16 PM
