Trade: flooring contractor
Laminate Flooring
We are installing an Armstrong floating floor in new construction. We are at the wall and need to install around the bottom step. Are there any tricks to locking inplace? Also, how about door jams. It is very difficult to get the last piece in tight. Do we need to cut the lip?
Please help. |
Re: Laminate Flooring
Lock the last piece into the second to last piece first....that will allow you enough height to lock them both in at one shot.
Don't forget the expansion 1/4" against the wall. |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
You are a "flooring contractor" and don't know these very simple things about a laminate floor installation??
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Trade: Plumbing & Electrical
he is not a contractor. He is a DIY with his Lowes flooring. Who the hell does laminent in NC?
"....And then we all switch places when I ring the bell" -Adrock
Unfortunately, that's exactly what is going on the floors at my current new construction project. 2500 square feet of woven strand bamboo engineered flooring. The archy had originally specifed a laminated bamboo floor product called Gammapar. I had four flooring contractors come to the site to give me a bid and all four passed on the work immediately because the flooring has to go over a Warmboard radiant heat floor, and the archy had specified that all of the thresholds be set so that the flooring was nearly flush to the top of the thresholds, and the necessary 1/4" expansion gap be fillied with a reveal grade cork sliver. If you're not familiar with that Warmboard product, it is a 1 1/8" subfloor with grooves pre-routed into it to accept the hot water tubing. The top of the plywood is covered with a sheet metal skin that is also pressed into the routed grooves. It turned out that Gammapar does not warranty any of its bamboo flooring over radiant heat floors. I eventually found a bamboo product that was backed with a warranty over radiant heat, and a flooring contractor that had experience with gluing it directly to Warmboard and was also willing to warranty his work in writing. I don't like the laminated stuff so much, it all looks like cheap Pergo to me, and I hate the pad option that is under under some engineered laminated hardwood flooring. Too much flex for me. Matter of taste I suppose.
#6 | |
Knowledge Factory
Re: Laminate FlooringQuote:
I have had to rewrite architects specs, more than once!!!! Flooring manufacturer specs over rule architects every time!! Sometimes you have to be the educator to get the job, and sometimes they think they know more than you and you have to walk away..
Yeah, this architect is one of those guys who has attended some high tone eastern colleges, got his masters, and thinks he knows everything but has no practical field experience. Every time I tell him to show me where he's done a hinky detail before and how it has held up, he doesn't have an answer. I can't believe these homeowners haven't fired him. I've suggested it more than once.
Trade: Painting Contractor
I think the OP is talking about actual Laminate flooring (like formica tops) Bodger are you talking about a floor that is real wood top layer that is engineered in small laminated sections??
MAK Deco |
#9 | |
We've gone round and round with the flooring issue on this job. 5/8" thick versus 3/8". floating on a pad as opposed to gluing directly to the Warmboard, skimmimg with Ardex first and then gluing directly to that. who will and won't warranty, and on and on. One of the things I think I don't like about engineered flooring is that once it's on, that's it, any other work that has to be done in the house beter damn sure not damage the floors. Last edited by Bodger; 11-02-2008 at 11:03 AM. |
#10 | |
There is solid bamboo out there but some of it is engineered I have been looking into bamboo for my floor in my office but have not made up my mind yet.
MAK Deco |
#11 | |
Pic isn't great but here is a engineered bamboo top layer bamboo bottom layers ply...
Pic from phone camera..
MAK Deco |
It's absolutely amazing how much conflicting info there is out there. Gammapar flooring (a manufacturer) and another manuf. told me that what is clearly shown in your picture is never done due to moisture characteristics of bamboo. I guess they are trying to cite their method as an industry standard to increase sales.
#14 | |
I was told that form of bamboo was allow in basments because it was not solid...
MAK Deco |
What I was hearing was probably that although it was available, bamboo with ply laminates was not a good idea to put over a radiant heat floor due to moisture concerns. It was hard as hell to find a flooring manuf. that would warranty their product over Warmboard radiant heat, that much was certain.
#16 | |
MAK Deco |
#17 | |
Back east, cold winters, that would be different. I grew up in eastern Ohio in anouse that was built in 1890 and had one floor furnace to heat the entire house. I will never forget my feet hitting that cold linoleum floor in my bedroom on a frosty morning. I can remember going to bed some nights and I could actually see my breath in my bedroom, it was that chilly in there. I always understood why they used bedwarmers in te ld days, although I never had one. Should have used my mom's iron. Jerez, am I off topic enough at this point? |
#18 |
Trade: wood flooring
you can put bamboo over radiant...but in all applications i have done, manufacturer alwasy recommended floating it..
just get titebond T& G adhesive and glue together over 3 in 1 padding... that said, if manufacturer wont warrant it and is not recommended, then do NOT do it.. Use vertical grain bamboo...all bamboo products i have seen are layered in 3 applications, all bamboo. this because of the natural thickness of bamboo, that a solid 3/4 can not be naturally milled. |
#19 | |
That's crazy. While the house is close to the water, it still gets pretty hot around there. Same with the cold. AC, I can understand, but no furnace? Radient floor is not going to heat a spacious home. All that money on a new build and they gotta walk around with blankets and sweaters on. ![]() If I were you, I'd start planning on how to get HVAC in there after your archi is gone. Take lots of pics
#20 | |
| Laminate flooring issue with customer | beachwork | Flooring | 23 | 10-29-2008 09:35 PM |
| What to charge to pull up 325sqf of Laminate flooring?? | TileMan77 | Flooring | 3 | 07-17-2008 08:57 PM |
| Laminate Flooring.. Glue or Nail? | nick114920 | Flooring | 5 | 06-04-2008 10:24 PM |
| Air Bubbles in Laminate Flooring | Bigman | Flooring | 19 | 09-05-2007 10:07 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
