Laminate Floor Bid ?'s
Old 04-18-2011, 03:09 PM   #1
Small Project Specialist
RightConnection's Avatar
Trade: Home Repair and Maintenance
Rewards Points: 27
I've done laminate floors in the past, but usually one room here and there.
Now I've been asked to bid an entire house. I feel pretty comfortable with the composite price I've been using (includes removing carpet, cutting jambs, pulling and reinstalling baseboard) but because each room varies (some have the carpet gone, customer wants basemold instead of removing baseboards, etc.) I was curious as to how you guys break down a per foot cost.
Also, the customer was asking about laminate on his stairs. Personally, I kind of cringe at the thought (and I've never done it) but would be interested in hearing your thoughts.
Thanks
John
RightConnection is offline
Old 04-18-2011, 06:34 PM   #2
Full Service Renovations
MAD Renovations's Avatar
Re: Laminate Floor Bid ?'s
MAD Renovations is offline
Old 04-18-2011, 07:07 PM   #3
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
From the sounds of it you really don't know what you are doing. If you want to proceed with what you do know then charge for the installation by the square foot. Charge for the carpet removal by the square foot. Even if some rooms do not have carpet, then obviously those rooms would not be included in the removal portion of the bid. For the stairs you need to use stair nosings for the front of the stairs and fill in with laminate. For these I would charge per step. The price would be more if also doing the stair risers.
RhodesHardwood is offline
Old 04-18-2011, 08:15 PM   #4
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
Tree fitty .............
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 04-18-2011, 08:17 PM   #5
Dan_Watson's Avatar
Rewards Points: 2,466
Some awesome threads today. Making me want to go out and work.
Dan_Watson is offline
Old 04-18-2011, 08:20 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 1,672
Some of these questions should be on the DIY board.
Closed before the train wreck.
griz is online now
Laminate flooring under kitchen cabinets?? 232323 Flooring 41 07-19-2017 08:12 AM
Applying Poly over Laminate floor etbrown4 Flooring 15 10-28-2009 09:54 PM
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 10:12 PM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 07:57 PM
