Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 10-03-2008, 01:29 AM   #1
Trade: Design/build
Laminate floor in basement
Any thoughts out there on putting laminate flooring in a basement? I have read several posts that say it is ok assuming that a vapor barrier is installed underneath, but I have also heard that the vapor barrier will cause moisture to migrate out to the walls and result in mold on the walls. I have thought about installing a Dricore subfloor, but it seems that this would have the same result. Anyone have experience with Dricore panels?
wadswob is offline   Reply With Quote
Old 10-03-2008, 08:32 AM   #2
Trade: flooring
i haven't used dri core so i can't speak about it. However, i've installed laminate in basements and have replaced them just as often. Replaced one twice due to sump pump failures and repaired same floor because 1st floor toilet leaked through ceiling to the laminate. finally removed all laminate and tiled. if you choose to put laminate, make sure to get backup pump, redirect downspouts and in general check for any moisture problems.
olzo55 is offline   Reply With Quote
Old 10-03-2008, 04:00 PM   #3
Trade: Design/build
Thanks olzo. The basement has a history of mild flooding, but we had an interior perimeter drain (tied into the toilet drain) installed as part of this remodel. Hopefully it will solve the problem, but we won't know until the November rains come (in Seattle). Obviously, that is a risk. If it does work, I am more concerned about the effect of water vapor getting trapped under the floor...as opposed to flooding which will obviously destroy laminate if it happens. Any thoughts on the vapor issue would be great.
Old 10-03-2008, 08:51 PM   #4
Bellsfloors's Avatar
Trade: Professional Flooring Installer
If I were asked by a customer to install laminate in their basement and they told me information that you just told us, I would advise them to not even consider laminate period. Any moisture, and even high humidity from slab will cause the flooring to expand, swell, and fail. If they chose to move forward and do it anyway I would just advise to have good insurance as it will probably come in handy the first sign of trouble.
Tracy
Flooring-Tile-Waterproof Showers
www.AttentionToPerfection.com
Bellsfloors is offline   Reply With Quote
Return Grill in the Basement orson HVAC 7 10-02-2008 11:01 PM
Basement bathroom Input requested guyute65045 Plumbing 7 09-14-2008 08:43 PM
Floating Basement Walls McMasters Framing 15 08-26-2008 10:43 PM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 07:57 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 08:01 PM
