Laminate To Carpet
Old 11-28-2011, 11:20 PM   #1
Macsurfer83's Avatar
Trade: Flooring and Tile
Laminate To Carpet
Ive come across a increasingly amount of carpet installs where the the customer does not have and never had transition strips. Coarse when I install laminate i use a end cap but will they regret not having one there in the future? I think it looks good just especially the higher the oz of carpet.
Macsurfer83 is offline
Old 11-29-2011, 04:13 PM   #2
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
Re: Laminate To Carpet
They all get the transition strip. If they don't like the look, then it's time to step up... laminate isn't for them.
KnottyWoodwork is offline
Old 11-29-2011, 05:15 PM   #3
Estimator
jpincombe's Avatar
Trade: Nu-Way Carpet & Flooring
Yes all laminate flooring (floating floors) should have a transition strip at doorways, front door (unless the threshold has been installed with a shim to raise it just high enough to slip the flooring under the edge), and sliding doors. You can not install carpet well enough with the floating flooring moving up and down. I have fixed carpet next to a solid floor in a doorway and found that alot of times the stain on the wood flooring does not go over the edge enough so it looks weird. Then if you shim the tak-strip up, the pad is not high enough next to the tak-strip. The finished job looks good now but feels wierd when walked across and does not wear well. I wished all doorways that had hard wood ending there had proper transitions. If the manufacture does not have the proper transitions we us the "Versatrim" company they make transitions for all most all types of floors.
jpincombe is offline
Old 11-30-2011, 09:57 AM   #4
Rewards Points: 512
For hardwood transitions, I always make my own, and prestain the outer side. It solves the color difference issue, and takes hardly any time.
Old 11-30-2011, 10:15 AM   #5
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
Had one builder who would never use transitions. I always warned him that my carpet was tight and would not wrinkle but butted against my carpet the lam would buckle. He went out of business, imagine that.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 12-12-2011, 02:44 PM   #6
tom wentzwood's Avatar
Trade: Hardwood flooring
Rewards Points: 25
I always recommend to customer on est about all door ways for transition , i have came across that my self and some times matching could be tough especially if product was discontinued . good luck with that tom wentzwood
tom wentzwood is offline
Old 12-12-2011, 06:16 PM   #7
Estimator
jpincombe's Avatar
Check out www.versatrim.com they have all differant colors even stainable ones.
John P
Old 12-12-2011, 09:01 PM   #8
Floors San Francisco
hawaii's Avatar
Trade: Flooring
Rewards Points: 75
Unfortunately you have to use transitions moldings, T-moldings, end caps on all floating floors. I think it does not look good and is just a piece of potential tripping over. On a high end projects architects choose the hardwood floors and tiles or carpet so it can have a nice and smooth transition, without the difference in level.
http://www.davincifloors.com/
Da Vinci Floors surfing and sanding.
Honolulu Hardwood Floors San Francisco I Hardwood Floors Hawaii
hawaii is offline
Old 12-13-2011, 07:11 AM   #9
Flooring Installer
Trade: flooring
Rewards Points: 48
If they would just explain to consumers that laminate is temporary flooring. it would solve many of the problems. And it IS just temporary flooring.
Armstrong certified
Old 12-13-2011, 07:40 AM   #10
Rewards Points: 512
Not to mention they're higher end materials...
Carpet Laying Tips Bozzy Flooring 122 11-16-2015 05:59 PM
To all you Carpet owners.. Check this out AcademyHardwood Carpentry 7 10-13-2009 09:33 PM
Floors by Joe - Carpet, Laminate, Title, Ceramic, Vinyl, VCT FloorsbyJoe Help Wanted or Looking For Work 0 05-09-2009 05:23 AM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 07:57 PM
Putting 12mm laminate on carpet knothead Flooring 17 04-23-2008 04:56 PM
