Laminate Before Or After Cabinet Install
What's going on everyone...I am remodeling the kitchen, got new cabinets and everything on the way...I am looking at either Armstrong or Quick Step laminate flooring...I have been to a few different places and get a different answer everytime
Re: Laminate Before Or After Cabinet Install
I suggest installing the cabinets first. You will probably replace the flooring or have to effect a repair before you replace the cabinets. Trying to cut the flooring under the toe kick will have you inventing new words.
Flooring Guru
Trade: Sales Manager
cabs first 100%
it is impossible to install cabs on a floating floor. well I guess it's possible but very stupid. anyone who told you it may be o.k. needs not to ever give you flooring advice again. this info is WELL known in the floor community.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
my experience is in commercial construction and it does not matter what way you go, before or after the cabinets, but then again that is VCT, and most places redesign when a new tenant occupies, and it is not your house so they do not care as much. it is possible to do it before but like teetor said if you ever want to change the flooring it will be more difficult.
Flooring Guru
in new construction residential or commercial, or a complete re gut of an area or areas, it is always possible to install under cabs if it is not a floating floor.
yes, it is a good idea, cause if you rearrange the cabs down the road, you may not have to redo floor (MAYBE, most likely yes). If a floating floor, or just a floor project, cabs should stay in place.
| Getting laminate under door casing and jambs | Blackhawk | Flooring | 6 | 01-02-2008 04:14 PM |
| New Cabinet Install Today | In_Mexifornia | Carpentry Picture Post | 7 | 06-20-2007 07:42 PM |
| Laminate Floor | Richard | Flooring | 15 | 12-22-2006 12:59 PM |
| Tile or Laminate | jwaldman97 | Flooring | 15 | 10-14-2006 06:41 AM |
| 1,000 questions about laminate | dianna | Flooring | 6 | 06-20-2006 12:19 AM |
