Intalling Wood Engineered Flooring Over Concrete.
Old 03-17-2009, 09:57 PM   #1
combuilder's Avatar
Trade: commercial building mechanical
Question
I am trying to decide what type of engineered floor I safety can use in my condo. The floor is concrete and shows no signs of moisture. I would like to glue down acoustical cork (requirement of the building) to the concrete then install the engineered hardwood over the cork. I have two choices. The first is Armstrong locking hardwood, product number EL5MB12NALG. The second choice is Armstrong Fenton Crest Natural 6559N. I’m asking the question because someone told me that the locking hardwood product is not suitable for glue down, but the Fenton Crest 6559N is suitable for glue down. Which is correct? Does it matter? Because in either case I’m going to glue down the cork then install the planks over the cork. Another concern I have is weather or not the planks will lay down properly when I do the glue-down versus the floating floor without using glue. I am very confused at this point. Please help.
combuilder is offline
Old 03-17-2009, 11:23 PM   #2
Old school Ranger
floorinstall's Avatar
Trade: flooring
Re: Intalling Wood Engineered Flooring Over Concrete.
Either floor will perform well in you circumstance. Since you are using cork I guess that it safe to assume that you are not on the ground floor. The moisture level of the floor should be well within limits but it is best to at least do a mat test just to make sure. The manufacture can tell you if the floor can be glued. The biggest difference that you are going to see is the Floating floor has a tendency to have a hollow sound as opposed to the glue down floor. Be sure to level your floors to manufacture specs before you glue down the cork. We do a lot of these floors in the condo's in Destine Florida. I have not had any problems with either method installed over cork.
floorinstall is online now
Old 01-30-2011, 05:54 PM   #3
Custom Builder
Chris@Sunrise's Avatar
I thought you already had flooring over cork and were having problems with it. Are you looking for us to help you hammer the guys who laid it? Call the installer..
Chris@Sunrise is offline
Concrete To Wood Membrane TIMS Concrete & Paving 2 04-09-2008 11:30 PM
Connecting wood floor joists to concrete block structure in century home. bob_cntrctr Masonry 12 02-26-2008 12:27 PM
I would like to know the best way to install 3/4 hard wood on solid slab concrete amberwood425 Introductions 6 09-26-2007 06:07 PM
New Wood Flooring Business?? Pennjav35 Flooring 7 07-27-2006 09:57 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
