Radiant Heat
Trade: Electric Radiant Floor Heat
Insulation Under Radiant?
Hi, guys. I am a radiant heat component supplier, and I am trying to get a better insight on how these products are actually installed.
Specifically, I am looking at installing under non-tile surfaces. Hardwood, laminate, vinyl. In Europe they are using a 1/4" thick Extruded Polystyrene (rigid sheets) called Depron when installing under laminate or vinyl. There also seems to be a softer roll-out material used by some installers. I haven't seen anything like that in my search in the U.S. I can find Polystyrene, but only 1" thick or more. Is the material around, and I haven't found it? Or do U.S. installers use a different insulation under radiant? Or do U.S. installers skip insulating under the radiant, and instead trust the fiberglass batts under the sub-floor in the joist space? |
#2 | |
Chief outhouse engineer
Trade: mason
Re: Insulation Under Radiant?Quote:
Sounds like fan fold to me or something like that, I'v seen it in 4 foot widths folded 2' wide total length is something like 20' easy to cut down to a size that fits.(like between joists)
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
| Tags |
hardwood, insulation, laminate, radiant ![]() |
| Tile over hydronic radiant heat | angus242 | Ceramic & Stone Tile | 23 | 05-20-2010 10:06 PM |
| insulation types for new buildings | sprayseal | General Discussion | 14 | 10-12-2009 07:14 AM |
| Radiant vs rigid insulation or BOTH how much of each | wolftrap | Insulation | 3 | 08-29-2008 03:34 PM |
| Radiant Insulation? | Construction15 | Insulation | 0 | 07-07-2008 02:14 AM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
