Insulating Under Laminate?
Old 12-06-2011, 02:37 AM   #1
Fieldings's Avatar
Trade: Finish Carpentry/Renovations
I have a customer looking to place flooring in the basement (on concrete). I recommended using tile with heat pads in high traffic areas. It was a little too expensive for them, I am not too familiar with laminate. Is there an underlay product that offers some kind of decent insulation? Or is carpet the best option if cold feet and price are issues? I could make some calls but I thought i'd see what turns up here. Flooring isnt my area of expertise and would like to hear some recommendations. Thanks.
Fieldings is offline
Old 12-06-2011, 01:06 PM   #2
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Re: Insulating Under Laminate?
If height concerns arent an issue. 2x4 Sleeper system with foam board in Between?
I recently layed a floating floor over a slab and used 6 mil vapor barrier and a compresed, recycled fiber padding.
Actually helped with keeping some cold off the floor.
Good luck!
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 12-06-2011, 03:38 PM   #3
Fieldings's Avatar
Good luck!
Hey thanks, the sleeper system would be a goon one but they don't want to replace the floor in all the rooms. (we would have a 1.5" step)
That second idea would work. Do you think it would be much better than to use the underlayments that say they are a VB and are also 'foamy'?
Old 12-06-2011, 03:52 PM   #4
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Any interest in a heated under-layment or is that what you were referring to with the tile option above that was to expensive?
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 12-06-2011, 04:06 PM   #5
Repair & Renovation
Rich D.'s Avatar
I never trust those underlayments that say they are vb and underlayment all in one.. I the one I just used did have the vb attached but it was super thin and ripped all over the place. I just used my own 6 mil...
Also the foam type of underlayment is crap.
Rich D. is offline
Old 12-07-2011, 06:41 AM   #6
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Carpet is cheaper... Just dump in and move,on to the next job..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 12-07-2011, 08:34 AM   #7
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
Is the floor dry 365 days of the year? And what I mean by dry, is the moisture the same as the concrete walls? Unless you know for certain I would shy away from anything other than plastic.
davitk is offline
Old 12-07-2011, 07:58 PM   #8
Fieldings's Avatar
Interesting. How would you determine this forsure?
Old 12-07-2011, 07:59 PM   #9
Fieldings's Avatar
Definitely considering this.
laminate at the top of stairs bluebird5 Flooring 7 11-28-2011 12:12 AM
Applying Poly over Laminate floor etbrown4 Flooring 15 10-28-2009 10:54 PM
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 11:12 PM
What to charge to pull up 325sqf of Laminate flooring?? TileMan77 Flooring 3 07-17-2008 08:57 PM
