Installing Solid Maple Flooring On Advantec Subfloor With No Fasteners - Flooring - Contractor Talk
Old 01-24-2018, 08:09 PM   #1
ryanthereal's Avatar
Rewards Points: 8
I am in the middle of a garage build with a shop downstairs and the upstairs being left unfinished to be converted to a living space in the future. The 4" slab has PEX laid for hydronic heating. The plan was to for the upstairs to have some other heating option to be determined when they are ready to finish the space. I just finished the rough framing including the subfloor and steps. Now, my customers are asking about the possibility putting hydronic heating in the upstairs floor, as well. They would want that to go in now in this initial phase so that it could all be set for when they finish the space.
I dont want to raise the height of the subfloor because that would throw off the steps. What I would like to do is tack the PEX up under the advantec with aluminum heat transfer plates, insulation, and a radiant barrier below, but if I put the pex flush against the subfloor, it will be in the way of future flooring fasteners.
Im ready to run the electric but if I am going to put PEX in the floor, I would rather do that before I have wires running everywhere.
What do you all suggest? Is there an option for running the pex through the joists while leaving space for hardwood flooring fasteners?
ryanthereal is offline
Old 01-24-2018, 08:25 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,900
Re: Installing Solid Maple Flooring On Advantec Subfloor With No Fasteners
Running the pex not in contact with the floor and without heat transfer plates will lower the btu output quite a bit.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
sparehair (01-26-2018), TNTSERVICES (02-10-2018)
Old 01-24-2018, 08:27 PM   #3
Rewards Points: 8
My customer has a bunch of rough cut maple 1x6 which he had logged from his land. He just had the idea of getting it shaped into flooring to be used in the garage apartment I'm building for him. He also wants hydronic radiant floor heating underneath. The garage is already roughed in and the floor elevation set. Problem is, the flooring isnt ready yet, and pex tubing running under the subfloor would be in the way of the flooring fasteners. Is there any way to lay a decent solid wood floor on an advantec subfloor without fasteners? Sounds like a pipe dream to me, but I figured I would ask on here, anyway, before I tell him it cant be done.
Old 01-24-2018, 08:48 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,797
Threads merged. Please do not start multiple threads with the same subject.
Tinstaafl is offline
Old 01-24-2018, 09:10 PM   #5
Mordekyle's Avatar
Rewards Points: 3,836
Originally Posted by ryanthereal View Post
My customer has a bunch of rough cut maple 1x6 which he had logged from his land. He just had the idea of getting it shaped into flooring to be used in the garage apartment I'm building for him. He also wants hydronic radiant floor heating underneath. The garage is already roughed in and the floor elevation set. Problem is, the flooring isnt ready yet, and pex tubing running under the subfloor would be in the way of the flooring fasteners. Is there any way to lay a decent solid wood floor on an advantec subfloor without fasteners? Sounds like a PIPE DREAM to me, but I figured I would ask on here, anyway, before I tell him it cant be done.
ISWUDT!
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
ryanthereal (01-24-2018)
Old 01-24-2018, 10:03 PM   #6
Rewards Points: 8
I admit, I have only ever done radiant floors in concrete slabs on grade, but I have found lots of resources telling me this is a way do it when you have a joist system in place and
you can't spare to raise the floor's elevation.
My plan was to put 1/2" PEX 8" O.C. throughout. The upstairs is only about 650 sq ft, and the building has a heat loss of about 50,000 BTU.
Old 01-26-2018, 11:00 AM   #7
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,256
Why don't you lay the floor, then install the pex.
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
Morning Wood (02-15-2018)
Old 01-26-2018, 11:01 AM   #8
sparehair's Avatar
Also, tell your flooring installer to use 1.5 instead of 2 inch cleats.
Old 01-30-2018, 12:58 PM   #9
madmax718's Avatar
Trade: General
Rewards Points: 3,252
the problem is the home owner and his custom flooring- if he does it to correct dimentions, you'd be ok. 3/4" + 3/4" =1.5", espeically if your using a stapler on a t&G. The angle nail wont puncture the subfloor. Add some underlay and you'd be golden.
madmax718 is offline
Old 02-10-2018, 02:45 PM   #10
AustinDB's Avatar
Rewards Points: 878
is the space going to be continually conditioned (heat/AC)? Even the 2-1/4" solid wood flooring shrinks in the winter and if the way he get's the tree's cut may or may not add to the dimensional instability (movement).
I would try to talk the client into gluing down an engineered floor or using tile. Tile wouldn't be my first choice over a large span floor system unless I knew the deflection was not an issue.
AustinDB is online now
Old 02-11-2018, 07:00 PM   #11
90%-er
onmywayup's Avatar
Rewards Points: 1,652
Can you glue down regular hardwood? I install a lot of flooring, but it has always been floating stuff, or glue down engineered.
onmywayup is online now
Old 02-15-2018, 07:49 PM   #12
Box Builder
Morning Wood's Avatar
Rewards Points: 9,244
Absolute first thing to do would be to bitch slap your customer, and then yourself for letting them F your schedule up and be wishy washy about finishes and timing.
If they want to do a solid wood floor above the garage, then you'll have to do staple up underneath the floor. Also, maple is not my first choice for flooring with radiant heat.
You could use climate panel, which is 1/2" plywood and then apply a 1/4-3/8" thick flooring surface over that. That would keep you within specs for your current framed stairs. But you would be stuck with a floting floor probably.
Is this apartment going to be used alot, or is it an extra in law apartment? Radiant might not be a good choice in general if it won't be used alot. Honestly, I think I would look into just yanking your stairs and rebuilding them so you can add the extra 1/2". Are you already maxed out on riser height or something? All you really need to gain is 1/2". That should be easy enough. I mean how many risers are there. You could probably get that with just shimming.
Morning Wood is online now
methods for installing glass in FR solid core birch door AustinDB Finish Carpentry 11 02-07-2015 12:08 PM
Solid groove bambo flooring NestoG510 Flooring 26 01-10-2014 03:18 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
Mullican Flooring Sold at Lowe's GHI General Discussion 2 05-19-2010 03:09 PM
Installing unfinished oak flooring at 35% humidity.. Texwing Flooring 20 01-06-2009 09:00 AM
