Installing Solid Hardwood On Slab
Old 05-24-2013, 03:20 PM   #1
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
After having failed the first time I want to make sure it gets done right this time . I'm installing a 1200 sq. ft. dance floor for a dance studio . The problem that I had the first time is the moisture from the concrete slab on grade eventually made it's way through to the solid oak flooring . I first noticed the floor start to cup after a few months and then start to buckle after 6 months . Time was a big issue and I could'nt follow all the proper procedures such as proper acclimation of the wood . I used a 6 ml vapor barrier on top of the concrete and 3/4'' ply on top of the vapor barrier . My biggest concern now is what to use on top of the concrete to seal it from the moisture . I tested the concrete with a moisture meter and it shows on average 12% moisture . I also tested the plywood and oak flooring , ply was 10% and oak was between 7-10% moisture .
The problem with the moisture barriers is that when fasteners are used it no longer is a moisture barrier . The plywood is used to help soften the dance floor and when fastening the ply to the concrete it penetrates the moisture barrier . I'm thinking to put a moisture barrier above and below the plywood . Thoughts on that ? Maybe 6ml on top of concrete and M.V.P. on top of plywood . Can M.V.P. be used to install the solid oak floor on top of plywood without fasteners ? I have no experience with M.V.P. or similar product . I also know I have a moisture problem with the concrete slab from previous flooding so i'm I going to fail again ? Should I look into using engineered flooring ? Theres a lot to think about and I know some off you floor guys could lead me in the right direction . Thanks Ken .
Eaglei is offline
Old 05-24-2013, 03:56 PM   #2
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
Re: Installing Solid Hardwood On Slab
Isn't the recommendation two layers of plywood and I think two layers of 30# felt, or something like that, i'm sure someone will be along to correct me, or be a little more specific.
TAHomeRepairs is offline
Old 05-24-2013, 04:07 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 1,792
Not sure if I posted this in your other thread on this topic.
Look at this product:
http://www.moxie-intl.com/existingconstruction.htm
Give them a call & explain your problem. They are knowledgeable & very helpful folks. I've used this product several times with excellent results.
6 mil is a vapor rertarder not a vapor barrier.
Have you done a RH Test on the slab?
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Eaglei (05-24-2013), PrecisionFloors (05-24-2013)
Old 05-24-2013, 06:57 PM   #4
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
No moisture barrier sandwich! Ardex has some excellent moisture mitigation products. I would go that route with two layers of plywood ran perpendicular to one another, only fastened to each other - not the slab. A floating subfloor if you will.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following User Says Thank You to PrecisionFloors For This Useful Post:
Eaglei (05-25-2013)
Old 05-24-2013, 07:14 PM   #5
fjn's Avatar
Trade: mason
Rewards Points: 9,136
Never used this stuff,may have some potential.
http://extremehowto.com/installing-a-floating-subfloor/
fjn is offline
Eaglei (05-25-2013)
Old 05-24-2013, 07:50 PM   #6
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I'm no expert on hardwood floors as most of the times I see them installed it was on block and beam floors but the couple of times I see them installed on a slab on grade they used a foam board glued to the concrete with the seams taped and then plywood glued to the foam board with the hardwood glued or stapled to the plywood. No idea how it held up long term but I ain't ever seem anyone over here ever do them like this. May be worth looking into.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Eaglei (05-25-2013)
Old 05-24-2013, 10:24 PM   #7
Tom M's Avatar
Rewards Points: 6,448
So to add to the concern are we using SS fasteners with the base layer of ply treated? I dont like the idea of punching into the slab with anchors either, defeats the vapor barrier.
Tom M is online now
Old 05-24-2013, 11:19 PM   #8
ccoffer's Avatar
Rewards Points: 1,140
My fave method is to just plop 3/4 inch Advantech down over 10 mil polyethylene. If you're paranoid about panelization, just take some metal flashing and sister everything together.
It's great. Super fast. Super stable.
ccoffer is offline
Old 05-24-2013, 11:21 PM   #9
ccoffer's Avatar
Attaching plywood to concrete is dumb. A waste.
ccoffer is offline
Old 05-25-2013, 11:12 AM   #10
Eaglei's Avatar
I used the hilti zamak pin bolts , drill first then drive them in with a hammer . I'm not sure what metal there made of but there made for concrete and very expensive considering the amount I needed .
Eaglei is offline
Old 05-25-2013, 12:42 PM   #11
Tom M's Avatar
My concern was with treated plywood and ground contact normal fasters will corode.
Tom M is online now
Installing solid hardwood floors over particleboard dsmoser Flooring 37 08-20-2017 10:02 PM
Paint or Solid color stain? kenmorgen Painting & Finish Work 8 04-27-2013 12:03 AM
5 Best Hardwood Floor Tips And Save Money Too! Benoakley Flooring 6 08-17-2009 12:49 PM
Installing Hardwood. tips and what to look for....in a finishing contractor? J-Peffer Flooring 3 03-24-2009 08:58 AM
How to Install Solid Hardwood Flooring on Concrete Foundation gilamherst Flooring 13 02-05-2005 06:02 PM
