Trade: masonry
Installing Slate Tile
i have an 800 sq ft slate tile job coming up this summer.it is 16x16 tiles.my question is what would be the best thin set to use?
thanks
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Flooring Guru
Trade: Sales Manager
Re: Installing Slate Tile
What is it being installed on?
I always just use rapid set.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Master Craftsman
Trade: Rustic interior woodwork
I checked into laying slate once and found out it is alot of work. I was told to use a white mortar thinset that is disigned to be put on thicker. I don't remember the name but a good tile shop should be able to help you. Another thing that I was told was to seal the slate before installation to keep mortar from sticking and staining it.
Just what little I know and it may not be right. Dave.
Do one thing at a time, do it well, then move on. http://www.bigdaveswoodworks.com |
Tile Setter
Trade: Ceramic Tile, Marble, & Stone
I use grey Versabond for just about everything.
The only time I use the medium set, Marble & Granite Mortar, is when I am setting marble and granite, using a 1/2 trowel as well. For 16x16 slate, I would probably still use the Versabond but also step up to the 1/2 trowel due to the irregularities in the slate. By the way, I hate slate. I hate the irregularities, and I think the stuff is ugly. Oh... and it flakes apart gradually. Stuff seems popular as of late too. I always try to sell them on a porcelain imitation slate or stone which looks so much better and lasts, plus saves them money. Upcharge for it, cuz it will need sealed before grouting, and then sealed again afterwards. - Bob
Classic Tileworks http://www.classictileworks.com Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio |
D.C.
Guest
Posts: n/a
Tell yer client slate flakes, and you'll never be able to seal it addequately so you cant warrant it. Whatever you seal, will flake off.
Trade: Flooring contractor
Not if its a honed slate.
tile contractor
I agree with Tileworks-- no need for white thinset with slate. It's not a translucent stone like marble is.
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
tile mason
A great thing:
you can buy slate in ceramic form check out Marazzi "Imperial Slate" ohhhh - aghhhh it wont be as brittle it wont stain you dont need to worry about which spectacular thin-set to use slap them ceramic puppies on with some dag-on toothpaste it's just you'll have to re-sell your customers, and break out the change order forms |
tile mason
p.s. - I found it for $3.50 per sq ft at a local tile shop
I don't know how many middlemen, but it's not too shabby |
Durabond d-70. It is great for large format stuff. Slate is notorious for lipping. You can use d-70 with a 1/2 in u-notch if you want. It is also a GUARANTEED CRACK SUPPRESSANT.
#11 | |
Tile Contractor
WHOOAAAH Hold on there Turbo!
IS NOT a "Gauranteed Crack Suppressant" product for stone tiles. "Crack protection does not apply to natural stone tiles."
TO OUR VALUED CUSTOMERS: Please manage your children. Any children unattended throughout the day will be given a Free Mountain Due at our regular quiting time. |
bootsmckiber
Trade: tilesetter
I'm putting travertine on heat mats(64 units)seeing I'm paying for my own mud,what would be cost efficient plus do a good job,Thanks
Mike p.s. I'm setting on concrete(clean) slab. I'm thinking white modified. Also got 3000 sq.ft. of slate on clean concrete floors,modified thinset? |
Trade: Tile
Seal the slate after you thinset, before you grout.
Tech Geek
Trade: Property Management/Facilities Manager
this thread is 3 years old.
EDIT: Welcome to CT. |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| shingle over slate tile | Home Serve | Roofing | 4 | 05-07-2007 09:21 PM |
| Slate tile finishing | Stevo | Flooring Picture Post | 10 | 04-12-2007 04:41 PM |
| Slate Tile | highlife77 | Flooring | 4 | 03-01-2007 06:23 PM |
| Slate Tile for Outside Patio? | ridgeline_dev | Flooring | 6 | 08-20-2006 09:51 PM |
