Installing Hardwood Over Tongue And Groove Subfloor
Old 03-10-2009, 05:38 PM   #1
CT Cruiser's Avatar
I'm getting ready to install solid 3/4 oak and I was wondering if anyone can tell me if it is advisable to install it right on top of the tongue and groove hardwood subfloor that is on top of the floor joists. I cut out the particleboard that was installed over it to raise the carpet level with the other floors and I discovered the tongue and groove. It has about a 1/3 inch gap between the boards for some reason but the tongue goes into the groove. I plan on laying paper down but any other suggestions or words of caution would be appreciated.
CT Cruiser is offline
Old 03-14-2009, 06:16 PM   #2
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Re: Installing Hardwood Over Tongue And Groove Subfloor
I'd do it, but its not a bad idea to put some plywood down first. Is this a project for you, or a home owner? I don't think it would be a problem if the budget doesn't allow for the plywood. Just make sure to strike lines for the joists and nail on top of them to try to tie into them.
HandyHails is offline
Old 03-14-2009, 06:23 PM   #3
KemoSabe
loneframer's Avatar
I would renail the subfloor to the joists and staple down a layer of 5mm luann plywood, glued if possible, then rosin paper, finally flooring. I think you may get movement in the old T&G decking.
loneframer is offline
Old 03-14-2009, 10:05 PM   #4
Knowledge Factory
Floordude's Avatar
As long as you go the opposite direction, or at a 45º, there shouldn't be a concern. It get hairy, when you try to go the same direction as the planks.
http://www.AustinFloorguy.com
Floordude is offline
The Following User Says Thank You to Floordude For This Useful Post:
the big 12 inch (03-15-2009)
Old 03-14-2009, 10:10 PM   #5
Teetorbilt's Avatar
I can't add to whats been said. It's an excellent subfloor from all perspectives.
Albert Einstein
Teetorbilt is offline
Cathedral Roof Tongue and Groove Ceiling Pricing Help Kel-Kat Finish Carpentry 14 10-23-2011 07:13 PM
hardwood floor and door jambs woodworkbykirk Finish Carpentry 33 12-05-2009 09:26 AM
fastening ipe tongue and groove AltonAyer Decks & Fencing 0 09-05-2008 08:51 PM
Gluing Tongue & Groove Planks to the Floor Journeyman T Flooring 11 10-21-2007 07:02 PM
tongue and groove cedar and hardwood floors harpstconst Finish Carpentry 2 05-23-2005 07:43 PM
