Trade: Siding , stucco
Installing Hardwood Over Hardwood?
I have living room and dining room ,there is 3/4" difference in elevations .I like to bring them up to same elevation. Existing floor is oak hardwood .is it ok to install new 3/4" hardwood over existing hardwood to raise floor elevation?
Tile Contractor
Re: Installing Hardwood Over Hardwood?
Just curious.....which stucco method do you use in your stucco jobs?
egotistical prick
Trade: Wood Inlay
What kind of wood flooring is already installed?
Trade: Hardwood flooring contractor
An existing t&g floor is an acceptable subfloor for an new floor. Ideally go perpendicular to the floor. So you have to remove all the baseboards in the room? Just make sure there are no loose boards, etc
Chris Frate Pasquale Floors |
Knowledge Factory
When siding a gable, how do you leave room for the vent?
Handle It!
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 02-10-2009 at 12:58 PM. |
Trade: home builder carpenter Central Alabama
Ive have done just that. We only had an manual floor nailer (without air) so i had to really come down on the hammer to get through all that oak. It turned out great.
Tighter joints.. More tendonitus. sp?
cant get a hit when they are that tight...
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Trade: electrical
How about a floating floor over an existing hardwood floor. I have an old 1947 home hardwood has seperated and had carpet over it for about 12 years. Would like to put either hardwood down floating or nailed. Does anything have to be done to the old floor????? Thank for your help!!!!!!
Trade: remodeling and restorations
What do you mean, the hardwood has "seperated"?
if the flooring is separated you may want to solve that problem first. installing a floating over that will just mask the problem.
most of the time those old houses are just settling and pulling the joists causing them to separate. that's an issue b/c it may be a bad settle ie footer issues. are they tight in the summer time? if so then its probably the humidity levels in your home.
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County. Bergen County's Premier Home Maintenance Provider. |
Trade: hardwood floor contractor 28 yrs.
I would try and lower the other floors!!
Floors San Francisco
Trade: Flooring
Hello.
Here in Hawaii and California it is not recommended and licesed contractor is not supposed to do it. Realty is that it could work and most likely would. If there is some source of moisture say the crowl space het water in the rainy season, or there is bathroom close, loundry it is possible there will be sole expouse to moisture and this migt lift the old floor and new. Considering that the old floor has been in the house for long time and never had problems then go ahead and do it. Dont install the floor the same dirrection as the old floor if you go with nail down, floating doesn't matte rreally. Now if you trying to hide some problems , not scraches but moisture problems you can be sure that sometime in the future the problem will get back. Good luck. Just make sure to use moisture barrier paper, and for floating extra moisture barrier can be thick paper. |
| The Following User Says Thank You to hawaii For This Useful Post: | dofrazie (02-17-2009) |
Trade: electrical
Thanks for you help!!!! I am going to use an Meritage engineered floor 1/2" thick and nail it down perpendicular to the old floor. The reason I don't want to take the old 3/4" t/g oak flooring out is the mess and the house was built with old rough oak sawmill lumber. Hope it works!!!!! Thanks again for your help!!!!!!
#17 | |
Re: Installing Hardwood Over Hardwood?Quote:
Why do you have to lay the new wood a different direction from the old?... |
#18 |
Trade: Design
Re: Installing Hardwood Over Hardwood? |
#19 |
Trade: wood flooring
my guess is this is a trick question.. answer is to offset wood grains to eliminate the bottom floor from opening the top floor from expansion.. on a 45 or perpendicular is guideline |
#20 | |
I was just curious as to how it would be answered.... |
| Installing solid hardwood floors over particleboard | dsmoser | Flooring | 35 | 07-13-2011 12:01 PM |
| Help Installing Hardwood over old/new Concrete Slab | Hages | Flooring | 7 | 06-04-2008 01:02 PM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Hardwood over hardwood? | dkillianjr | Flooring | 9 | 09-21-2006 09:07 AM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
