Trade: carpenter
Installing Hard Wood On Walls?
I have a customer who wants 3/4" hard wood, random widths, installed on his walls in his garage. He wants it to run vertical. I will need to fur the walls horizontal so I can run the oak vertical. Has anyone ever done this? Will I need to use 1x4's or 2x4's? Should I screw the furring? He wants random widths. The widest is 8". All will be 10' long. Should I glue it? what kind of glue? Do I just nails the tongue on the 8" wide boards or will I have to face nail some? should I use my bostitch air floor stapler or can I just use finish gun? If anyone has ever done this, I would really appreciate some insight. thanks
Re: Installing Hard Wood On Walls?
I've never even heard of this being done, but if that's what the cust. wants...... What type of wall is this going against? I'm thinking that it is concrete or you could go directly to it. ??
Trade: Log-Style Home Contractor, Custom Homes,Remodeling, Stone
I would fur out with 1x3's 24" OC then use a 15 guage finish nailer into the tongue, trim top and bottom, your done. Furring can be nailed on with 2 1/4" R.S nails.
Trade: carpenter
what my concern is, I dont want the 8" boards cupping. That's why I think I need glue behind it and maybe some face nails? The garage is stick frame. 24'x45'
There certainly is no harm caused by glueing, but let's face the facts here. If conditions are right, high moisture in wall, high moisture in board, flat sawn board(Almost a given with modern 8" board), humidity swings in room,etc, no amount of glue or nails will prevail over nature, wood will cup, warp, or bow.I would try to keep the wide boards to a minimum, apply a generous amount of top notch adhesive, and toe nail through the tongue only.
#6 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Installing Hard Wood On Walls?Quote:
As a side note, I would not warranty a bit of it either.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
You might consider going ply first, think subfloor. Lots of adhesive and a disclaimer in the contract. Gets you more nails in the tongue edge. I'd use construction epoxies.
If you're dedicated to furring strips, I'd use 1 X 4's, 16" OC, two screws per stud and the epoxy adhesive. 8" boards can generate a lot of force.
Trade: REMODELING CONTRACTOR
I doubt if the garage is heated, so you'll get alot of wood movement because of different moisture levels thru the seasons. I would tell the homeowner to expect gapped seams and some warpage in the future and then do as Teetorbilt suggested with the ply, glue and disclaimer.
Steve. |
Thom
Did a commercial job years back that used 2" finished oak strip floor on the walls. Sheathed with plywood then used the brad nailer through the tongues. Worked and looked great.
thom, 2" to 8" is a big jump when it comes to cupping, etc.
Trade: carpenter
so, if I end up usuing plywood for a sub-wall, can I use 1/2" or does it need to be 5/8 or 3/4? or do you guys think furring will be enough.
1/2" nailed to EVERY stud will hold it, I'd go 10p or better, 12" OC or better. Furring, my way, will hold it as well. It's not cheap, but neither are flybacks.
Trade: Flooring and Trim
I did something similar once.Put up T&G pine in the same manor. I had to go over sheet rock so I glued the entire surface with Roberts Hardwood Glue and also nailed the tongue to hold it till the glue dried. Came out ok but next time I will cut out the sheetrock and do the furring strip and glue and nail that. I think you are on the right track with that.
| which wood filler? | rocco | Carpentry | 10 | 03-18-2009 12:40 PM |
| New kind of Pressure Treated wood | karma_carpentry | Carpentry | 23 | 08-21-2008 09:06 AM |
| Bad wood | ron schenker | Flooring | 10 | 03-22-2007 11:45 PM |
| Wood people I need your help | Floorwizard | Flooring | 11 | 05-18-2006 09:07 AM |
| Bowed Walls on historic garage | genesisremodel | General Discussion | 2 | 03-16-2004 07:30 PM |
