Installing Carpet: Power Stretcher?
Old 10-11-2004, 12:08 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Is a power stretcher always required to install carpet? Or is something called a "kicker" sufficient?
Old 10-11-2004, 01:32 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Installing Carpet: Power Stretcher?
I do not install carpet but it is my understanding that installing carpet without a power stretcher is asking for trouble down the road. I am under the understanding that an installer trying to do a house without one is not someone you want installing your carpet.
If it is a little tiny area it may not be as critical as a normal size room.
Mike Finley is offline
Old 10-11-2004, 02:28 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
A power stretcher is the best choice for larger areas, even rooms.
closets on the other hand........
Floorwizard is offline
Old 10-12-2004, 10:52 AM   #4
Don Benham's Avatar
Send a message via AIM to Don Benham
A power stretcher is the only way to install stretched in carpet. A "kicker" is a positioning tool, not a stretcher. Anyone trying to use a kicker to stretch carpet is
  1. untrained
  2. a hack
  3. or, underpaid and trying to get too much work done in one day
A person not using the proper stretching tools will generally cut other corners as well. Such as, not using seam sealer, not allowing carpet to warm up to room temperature, etc.
My stretcher is used in every situation that it will fit. Even if I only use the power unit and a 2x4 in a hallway.
click here and follow the link to read the standards in PDF form. Don't let any installer or salesman tell you it's not neccassary.
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline
Old 10-12-2004, 11:28 PM   #5
Teetorbilt's Avatar
I remember when a kicker was all that we had and it worked fine unfortunately after a while your knee didn't.
Teetorbilt is offline
tips on painting baseboards with carpet floor and a tip for new painters Zeebo Painting & Finish Work 10 04-22-2011 06:42 PM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 09:57 AM
Power under carpet?? JamesNLA Electrical 4 05-16-2007 04:34 PM
any advice on installing carpet ? painterofeveryt Flooring 3 08-03-2006 10:16 PM
installing carpet onto stairs cynthiann Flooring 2 04-09-2006 12:08 PM
