Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 04-07-2006, 08:56 PM   #1
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Install 24"x24" Outdoor Granite
Is there any special thinset would you use to install Outdoor granite on:
1) Existing concrete steps
2) For a new patio ( dirt/grass under)
Thanks
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 04-08-2006, 09:23 AM   #2
Tile Setter
Trade: Ceramic Tile, Marble, & Stone
I've set slate on an outdoor porch/steps using versabond back when I was somebody elses helper. It has stayed there just fine. You might want to step up to a medium set mortar for the granite, unless you think it'll go down easy as it is.
I don't know of any thinset that will stick to grass {wink!}
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline   Reply With Quote
Old 04-08-2006, 02:19 PM   #3
plazaman's Avatar
- Bob
I've used portland & sand for my porch application.
On my under the deck application (dirt & grass), i first mixed portland and sand (very dry ) creating a bed. Then I mix cement & water )very watery) and apply it to the back of the granite. Then I place on top of the bed & level. Seems to be holding fine to this date. .. .
Old 04-08-2006, 02:22 PM   #4
plazaman's Avatar
- Bob
BTW, Im 100% confident in my work. I know therew more than 1 correct way how to do something. Just curious to see how others are doing it.
small install job. does this sound right? AGC Finish Carpentry 9 05-12-2007 11:28 AM
Alright businessmen ... I'm gonna give it one more try ... breakin even dirt diggler Business 30 02-27-2007 12:34 PM
correct way to install Michaela521 Electrical 1 08-13-2006 04:36 PM
labor rate to install crown bellerose Carpentry 14 08-08-2006 05:23 PM
outdoor tile install southcoastbuild Flooring 3 01-09-2006 11:03 AM
