Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 04-08-2006, 09:45 AM   #1
Trade: general contractor
Inlayed border
I am getting ready to begin a hardwood install and my client wants a inlayed border of a differant species of wood. The border consists of just one 3'' piece, one foot in from the walls around the perimeter of the room. I was wondering what the best way to go about installing the border would be. Any comments would be greatly appreciated.
Aptitude is offline   Reply With Quote
Old 04-08-2006, 12:20 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
what is the materials exactly?
Floorwizard is offline   Reply With Quote
Old 04-09-2006, 01:54 PM   #3
Trade:
It is really easy. I'll use the following words in the description - field (area inside border), border, and outside (area on the perimeter of the floor - outside the border)
I measure up and install the field first. I measure to have a full board as the starter and as the finisher along both lenghtwise runs of the edge of the border. Chalk all of your lines to the walls so you can find them later. I run the ends over the lines and cut after the feild is installed... See picture.
THen run a slot cutter on all sides that need a the groove - glue in a spline and run your border - use a biscut in the corners to keep the border from spreading. Install your border and then run the outside of the floor - I prefer to do these corners in a herring bone pattern for 90 degree corners and miters fir off 90 corners.
The photos are of a prefinished border and I did not particularily like it; but the clients loved it. I think borders are best in a site finished floor.
I have heard of people running the border first and it does not make any sense to me; but might to you - seems like a lot of extra work and precise cutting instead of careful measurements and using a calculator to plan your layout.
dsnAK is offline   Reply With Quote
Old 04-09-2006, 04:16 PM   #4
Thank you for your help the picture was a big help. How much do slot cutters run?
Old 04-09-2006, 04:24 PM   #5
Trade:
$30-40 - be very careful and do not rush it - you are removing alot of wood when you are routing.
THis is what happens when you do not pay attention..
Old 04-09-2006, 06:08 PM   #6
Teetorbilt's Avatar
Best is not to try to take it all in one pass. A couple of shallow passes will eliminate blowouts.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 04-10-2006, 04:48 AM   #7
Trade: Flooring
Send a message via Yahoo to Mike Costello
That has to be the best description of how to do something I have ever read in here. And pictures too!!!! AWSOME!
Mike Costello is online now   Reply With Quote
Old 04-10-2006, 11:51 AM   #8
Trade:
Thanks - I am surprised no one asked how the flooring was being laid. That job was a glue down over concrete of 5/8" bamboo. The concrete was right on the cusp of emitting too much moisture so I used Bostick's MVP. Worked like a charm and is still in great shape I am told.
Advice needed - border installation tim790 Flooring 5 07-11-2007 08:24 PM
how long for border aspenpainting Painting & Finish Work 1 07-06-2007 09:26 PM
Bathroom Tile Shower Remodel, 12" travertine with 4" alternating border MattCoops Flooring Picture Post 2 04-29-2007 09:12 PM
Truckers, Shippers, Brokers, Border Questions plazaman General Discussion 1 04-02-2007 12:53 PM
removed border with dif and left streak marks lornmastro Painting & Finish Work 5 08-25-2006 05:21 PM
