Hydronic Floor
Old 01-10-2018, 11:18 AM   #1
Scottystepp's Avatar
Hydronic Floor
I have a client with a 20x20 garage/shop that needs heat other than electrical. I really can't raise the height of the floor so I would need to install the pex into the exsisting (uninsulated) concrete slab by cutting/chisilling out the grooves for the pex. Removing the slab completely and insulate/re-pore is not an option due to cost. So would it be worth installing in the current slab from a heat loss perspective? I know they would be loosing heat downward but would it be more economical than heating the garage with an electric heater 4 months out of the year? (Ca.$100 a month in heating cost)
Thanks you.
Scottystepp is offline
Old 01-10-2018, 11:22 AM   #2
Mordekyle's Avatar
Rewards Points: 2,652
Re: Hydronic Floor
$400 per year is too expensive?
No, I don't think you'll save any money by putting floor heat in your garage.
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
rrk (01-11-2018)
Old 01-10-2018, 09:46 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 5,418
Re: Hydronic Floor
Heat pump and lots of insulation. Any modifications to save money are going to carry a high ROI. Insulation is probably the cheapest, but we don't know what it is now.
Peter_C is online now
Old 01-10-2018, 10:55 PM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,616
Re: Hydronic Floor
Heat directly into the space will be more efficient then via an uninsulated slab, and chiseling out space for the pex would be a lot of work. If you're trying to heat with an existing hydronic boiler (to use a cheaper fuel source maybe), then use baseboards or a unit heater. Or go with a heat pump, it'll be 1/2 the electric use, maybe better depending how cold your environment is.
Golden view is online now
Old 01-11-2018, 12:32 AM   #5
Jay hole's Avatar
Trade: General contractor
Rewards Points: 771
Re: Hydronic Floor
If you can chisel groves for hydronic tubing in a concrete slab, cheaper than removing the slab and placing new concrete.... I'll shake your hand.
Jay hole is offline
The Following 2 Users Say Thank You to Jay hole For This Useful Post:
Inner10 (01-11-2018), Joasis (01-11-2018)
Old 01-11-2018, 06:24 AM   #6
Joasis's Avatar
Rewards Points: 806
Re: Hydronic Floor
I cannot imagine cutting the slots in a floor for PEX. That is simply nuts.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
B.Johnson (01-11-2018), rrk (01-11-2018)
Old 01-11-2018, 07:59 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,056
Re: Hydronic Floor
This made me laugh.
Inner10 is offline
Old 01-11-2018, 08:43 AM   #8
B.Johnson's Avatar
Trade: Builder
Rewards Points: 466
Re: Hydronic Floor
It almost HAS to be a homeowner with lot's of time on his hands, otherwise it makes no sense.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
AustinDB (01-11-2018), Mordekyle (01-11-2018)
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
degreasing garage floor - prep for carpet MarkJames Flooring 5 03-25-2013 10:59 PM
exterior prehung door replace - uneven floor artinall Windows, Siding and Doors 19 12-24-2012 11:38 AM
FS: Panther Floor Stripper Scraper 6280 HD Allfloorremoval Contractor Swap 1 07-16-2012 09:45 PM
Cross-laminated PE vapor barrier under floating floor after leveling with sleepers sjkm Flooring 11 06-14-2009 11:03 AM
