How To Start A Floating Laminate Floor
Old 02-28-2012, 08:46 AM   #1
ACHighland's Avatar
Trade: Roofing and window cleaning
Rewards Points: 14
I'm a roofer by trade but I'm installing a floating laminate floor in my house and have a quick question. It's my understanding that I should nail down the first row to make sure I have a solid and straight starting point for the rest of the floor. I should also nail down the last row also? I'm asking because the flooring I bought at Lowes doesn't mention anything in the directions about nailing. Thank you
ACHighland is offline
Old 02-28-2012, 08:54 AM   #2
DavidC
DavidC's Avatar
Rewards Points: 2,006
Re: How To Start A Floating Laminate Floor
Get yea to the manufacturer's website and find the installation instructions before proceeding. It's not rocket surgery, but it does need to be done properly. Once you nail a floating floor it becomes a nailed floor instead. If you nail it on both ends it will likely buckle in the center.
If you haven't already, Lowe's does sell an inexpensive tool kit that will make life a bit easier for you.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 02-28-2012, 09:21 AM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Lock the whole row together then with a few guys lock the entire row in at once. Make sure you leave the recommended gaps all the way around the rooms. Undercut your door ways. Never, ever put a nail into this floor, ever. Might be cheaper for you to fix a floor guys leaking roof.
ohiohomedoctor is offline
Old 02-28-2012, 09:28 AM   #4
ACHighland's Avatar
Rewards Points: 14
That makes sense...thank you
Old 02-28-2012, 09:29 AM   #5
Mike-'s Avatar
Trade: Renovation Specialist.
Leave it "floating " you will have less issues if you do so. 1/4" against walls for spacing miniimum is usually required
Mike- is offline
Old 02-28-2012, 09:33 AM   #6
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 772
You can put a spacer between the floor and wall you're starting on to keep your necessary space while installing the rest of the floor.
dsconstructs is offline
The Following User Says Thank You to dsconstructs For This Useful Post:
Mike- (02-28-2012)
Old 02-28-2012, 08:19 PM   #7
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
If you nail down a floating floor...It is no longer a floating floor....
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
The Following User Says Thank You to JumboJack For This Useful Post:
pinwheel (03-02-2012)
Old 02-28-2012, 08:24 PM   #8
Why not?
Old 02-28-2012, 08:32 PM   #9
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Start against a wall with appropriate size spacers keeping the gap. Then run off that.
Dont nail... Anything..
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 02-28-2012, 08:34 PM   #10
manipulator of wood
I Mester's Avatar
Trade: general contractor
well.. its still a floating floor, except now you'll have waves to float over!
I just love the smell of sawdust in the morning!
I Mester is offline
Old 02-28-2012, 08:36 PM   #11
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Old 02-28-2012, 08:55 PM   #12
ernesto's Avatar
Trade: Licensed Contractor in AZ
Rewards Points: 150
Measure the width of the room and figure out if what you need to start out with width wise so you don't have to small of a cut on the opposing wall. Lock a row together on the longest wall, slide it up to the wall and scribe to it minus the cut you figuered before because we all know dey ain't straight. ( Note, sometimes you can start with a full plank but not with the locking mechanism along the wall side, that needs to come off either way) After scribing cut on table saw, put back together. Then go onto the following rows.
Hopefully your using product with a a UNICLIC locking mechanism, other wise you might have to lock in entire rows at a time. On long rooms this can be a PITA.
Top Floor Installation Co.
Tucson AZ
www.tucsonazflooring.com
http://www.floorsavior.com
ernesto is offline
Old 03-02-2012, 11:28 AM   #13
Aureli Construction
aureliconstruct's Avatar
Rewards Points: 75
if you have intentions of putting baseboard moulding, you put the floor down without nails and the put the baseboard on top so it doesn't move. if baseboard is already there you can lay it as normal, no nails, and add a quarter round at the baseboard.
www.aureliconstruction.com
aureliconstruct is offline
Old 03-02-2012, 11:50 AM   #14
boman47k's Avatar
So what does not move?
boman47k is offline
Old 03-02-2012, 12:00 PM   #15
Dirtywhiteboy's Avatar
Rewards Points: 8,044
It moves
Dirtywhiteboy is offline
Old 03-02-2012, 12:08 PM   #16
boman47k's Avatar
Originally Posted by Dirtywhiteboy View Post
It moves
Thats why I asked what Aureli was referring to.
It sounded to me like he/she was saying anchor the flooring down by installing the base tight to it.
Maybe I misread it.
Btw, I usually use pieces of the flooring scrap as spacers.
Not much experience at it, but I have done a little as in a few rooms for myself.
boman47k is offline
Old 03-02-2012, 12:17 PM   #17
boman47k's Avatar
I'll never forget a guy that had done some floors for a lady I did some painting for. When it was brought to his attention that the floor had a small area that would flex quite noticeably when stepped on, he proudly put a nail in it.
I don't know. If he only used one nail......maybe. Like I said, I just don't know. I do know, in general, nails and floating floors do not go together.
Maybe the guy should have read u p on floor leveler.
boman47k is offline
Old 03-02-2012, 04:56 PM   #18
ACHighland's Avatar
Rewards Points: 14
Ok so I finished and it looks really nice. I didn't use any nails thank god. It's not rocket science but took my time to make sure it looked good...especially at the transitions. I'll try and ad pics. Thanks for the tips.
How to start a floating laminate floor-image-162493766.jpg   How to start a floating laminate floor-image-108002286.jpg   How to start a floating laminate floor-image-2431248816.jpg   How to start a floating laminate floor-image-682391184.jpg   How to start a floating laminate floor-image-4205428900.jpg
The Following User Says Thank You to ACHighland For This Useful Post:
boman47k (03-02-2012)
Old 03-02-2012, 05:09 PM   #19
Repair & Renovation
Rich D.'s Avatar
Looks good ac highland.. how did you install your transitions?
Rich D. is offline
Old 03-02-2012, 06:35 PM   #20
DavidC
DavidC's Avatar
Nice job.
Good Luck
DavidC is offline
Electric radiant heat under laminate floor. Chris R. HVAC 5 10-13-2015 09:44 AM
Laminate over concrete with radiant heat in floor. Five Arrows Flooring 2 11-12-2010 08:57 PM
Questions about Bona Traffic over a new floating cork floor cej22 Flooring 7 09-19-2009 11:52 AM
Second floor water heater drip pan and T&P drains bob_cntrctr Plumbing 7 08-01-2009 09:58 PM
Advantage over nail down over floating floor (hardwood) 415moto Flooring 14 02-03-2008 09:30 PM
