Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 11-28-2007, 07:17 PM   #1
Remodeler
MinConst's Avatar
How to question.
I have this job I'm on. Rebuild a bay section that had small windows and half wall under the windows like a bench. Anyway the new windows open up the section to the floor and I am left with a section to add flooring to. The picture will explain better than I can I think. I need to know how to make a perfectly straight cut on the ends of the existing floor so I can run the new section in the other direction. I can make the cut with a circ saw but when I come to the walls is where I'm lost. Any recommendations?
Paul
Minichillo's Construction
Website One Man Shop
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 11-28-2007, 07:24 PM   #2
Trade:
I would doublestick tape a straight edge to the floor thick enough that a top bearing flush cutting router bit could run on. You can get bout 4" fom the finished walls that way. Doing the last bit with a bit chucked in a laminate trimmer will get you about 2" away. The last little bit could be done either way easily with a back cut hand saw.
user15686 is offline   Reply With Quote
Old 11-28-2007, 08:59 PM   #3
Old school Ranger
floorinstall's Avatar
Trade: flooring
the way I do it is double stick the straight edge and cut the floor using a makita battery saw with a carbide 4" blade. the portion that is unreachable I score really deep with a razor knife, I mean score really deep. Then after the fibers are cut about 1/8 to 3/16 take a Sharpe chisel and cut the boards at a slight back angle so the the new floor butts to the scored line and the under cut allows the boards to butt up without a gap.
floorinstall is offline   Reply With Quote
Old 11-28-2007, 10:30 PM   #4
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Festool plunge cut saw and guide rail. I'd use my Supercut to finish off the ends. Then use a router with the correct slot cutter, spline and install as normal.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 11-28-2007, 10:35 PM   #5
Certainly the low cost solution!
neolitic is online now   Reply With Quote
Old 11-28-2007, 11:20 PM   #6
Flooring? What's that?
Trade: Flooring
May not be the low cost solution ... but definately the proper one ... to just butt the joints even with nailing the edges will result in the butt joints to eventually become uneven ... over time with the house settling and possibly the bay sagging ... precision's solution is the best but the biscuits n slot cutter would be a close second.
Quality is not expensive ... It's PRICELESS !!!
www.doubledflooring.com
J DoubleD FLoor is offline   Reply With Quote
Old 11-28-2007, 11:26 PM   #7
Was mostly refering to the price of the Festool rig.
OP probably didn't have that kind of slop in his estimate
Figure that cutting the groove was a given.
Old 11-28-2007, 11:46 PM   #8
Cpt. Chaos
No, but if he bids it right the job will pay for that Festool setup and then he'll have it for the next one too
Precision Flooring
Old 11-29-2007, 06:20 AM   #9
Remodeler
MinConst's Avatar
Thanks for all the ideas guys I will mull them all over and figure out what works best for me. I don't have the Festool setup but it sure sounds like a nice investment.
I appreciate the help.
Paul
Old 11-29-2007, 09:03 PM   #10
Catch what you'll eat.
MattCoops's Avatar
Trade: Tile & Paint
Sell the customer on a tile floor and break out your change order.
Matt; tile contractor in Charlotte, NC
704-605-0907
Tweeting @MattCupan | read my articles
MattCoops is offline   Reply With Quote
Old 12-28-2007, 07:01 PM   #11
Remodeler
MinConst's Avatar
This is what I did,
I double stick taped a piece of oak to the floor over blue tape so I could get it back up with no damage. Ran my trim router down three passes and it worked great. I finished the ends with a knife and chisel. The joint came out perfect. Although I did no biscuits I am concerned about it not staying even. But the customer is OK with this. The floor was only like 3/8" thick and I wouldn't feel comfortable putting a biscuit in it. Not true hard wood floor it was a laminated floor with wood top. We will see how it holds up.
Thanks again for the tips they really helped.
Paul
Old 12-29-2007, 10:26 AM   #12
Trade: Flooring
Keep in mind. Sears sells a nice 3" circluar saw. Good for cutting in tight spaces and cuts deep enough for hardwood. You can also use a sawzall with a fresh blade near the wall if you already own those tools. A Fein multimaster and a sharp chisel can help you perfectly for the last couple of inches. A festool and rail guide will run you well over 1k.
Butting the wood to one another will be fine, jsut use a liberal amount of construction adhesive. Any of what I suggested will work fast cheap and easy if you have a site finished floor. Much harder with prefinished because you cant chip an edge.
GoodHouse is offline   Reply With Quote
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 08:10 AM
Can anybody answer this question? Chance Drywall 25 10-13-2007 08:22 AM
