Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-03-2009, 07:31 AM   #1
Jeff Teachout
Trade: Equipment Manufacturer
How in the heck do we remove old adhesive?
Okay, we have a problem. We have removed some old 8x8 asphalt (?) tiles, and what was left appears to be a heavy tar-like glue. This is in a hardware store, in one of the main aisles, which we are able to block off, and direct customer traffic another way. We are open 7 days a week. We are planning to use a 2-part epoxy finish on it. We do not want to use chemical stripper on it, because of the fumes/mess. Scraping doesn't get it. We tried a coarse wire wheel on a grinder. No dice. Again, we have a problem. Any ideas from you pros, other than calling one of you pros?
Porta-Crane is offline   Reply With Quote
Old 02-03-2009, 07:50 AM   #2
tomstruble's Avatar
Trade: siding
try a heat gun
tomstruble is offline   Reply With Quote
Old 02-03-2009, 07:56 AM   #3
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
I live near you, I'll do it...
As stated a heat gun should soften it up enough to chisel it off.
"Nothing is too good for you guys...and that's exactly what you're gonna get..."
"'Status quo,' as you know, is Latin for 'the mess we're in...'"
Cdat is offline   Reply With Quote
Old 02-03-2009, 08:44 AM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
Careful, Could contain asbestos.
When were the tiles installed?
After the tiles were removes was the tar shiny? If so you may be ok but should still take proper precautions.
I am not trying to scare you but considering that it is in a store you might want to think about removing it after store hours.
You never know when some customer will rock the boat.
Oh yea, Stop grinding NOW!!
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline   Reply With Quote
Old 02-03-2009, 09:05 AM   #5
Jeff Teachout
Probably 20 years ago. The adhesive is still kind of shiny, and still somewhat tacky. We had hoped there might be a way to slurry/paint over it, something that would allow the epoxy to adhere to it. We also thought about dusting it with rockite, eliminating the tack, while provided a base for the paint to adhere. We stopped the wire brushing, and there never was any dust emitiing from the work we were doing.
Old 02-03-2009, 09:07 AM   #6
Trade: wood flooring
your never going to get it off.
hire a pro concrete resurfacer
jamestrd is offline   Reply With Quote
Old 02-03-2009, 03:23 PM   #7
Trade: Flooring Contractor / kitchen & Bathroom
Send a message via AIM to Russo'sFlooring Send a message via Yahoo to Russo'sFlooring
hope this helps...
Had A SIMULAR PROB IN PAST. THERE IS A PRODUCT, TO REMOVE, EMULSION ADHESIVE, OR cUT BACK ADHESIVE. Sorry about the Caps, Woops..Anyway. Works great, need to locate a Flooring supplier/ Dist. and ask for it. For a quick cover, and works grerat, Pick up some ardex, floor Patch, mix to a creamy consistancy, and spread, put a Floor dryer, or Fan on and should cover, and be dry in aprox 1/2 hr, to 20 min. You can then instaill new Floor over Ardex, or smooth with a sanding screen, and Paint. Good luck
Russo'sFlooring is offline   Reply With Quote
Old 02-03-2009, 03:45 PM   #8
37 year installer
rusty baker's Avatar
Trade: flooring
Not only is the adhesive probably full of asbestos, the tiles you took up probably were, too. Just be careful, the last person I knew that got caught got fined $10,000. Throwing them in the dumpster is illegal in most states, too.
rusty baker is offline   Reply With Quote
Old 02-03-2009, 05:59 PM   #9
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
What he said!!
the big 12 inch is offline   Reply With Quote
Old 02-14-2009, 06:50 PM   #10
Trade: Decorative Concrete, Concrete restoration, Natural Stone Restoration, Etc....
how thick is the tar? also how many s/f overall
D.C.P.B. is offline   Reply With Quote
Old 02-14-2009, 07:05 PM   #11
37 year installer
Trade: flooring
It's not tar. It's called cutback. Don't scrape it. You will release asbestos in the air. That's a very big fine and dangerous to your lungs.
Old 02-15-2009, 12:42 AM   #12
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Encapsulate.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 02-15-2009, 11:10 AM   #13
Knowledge Factory
Floordude's Avatar
Ardex Feather finish!!!! Encapsulate it!
Rusty is right, your dealing with asbestos, both tile(VAT, the A stands for Asbestos) and black asbestos cutback adhesive. Pray no one has seen what your doing, and knows something and wants to make your life rough.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
The Following User Says Thank You to Floordude For This Useful Post:
sparehair (02-15-2009)
VCT Adhesive Failure dmranney Flooring 2 12-31-2008 09:53 PM
remove glued and screwed sub floor codaman General Discussion 14 12-19-2008 01:19 AM
how to remove vinyl lettering on trucks marc Marketing & Sales 10 11-10-2008 01:28 AM
Composite trim and adhesive questions JLTrim Finish Carpentry 4 10-12-2008 03:55 PM
Good trim adhesive? banctecbobn Finish Carpentry 16 09-18-2008 06:24 AM
