Trade: That's what she said
How To Get T&g Flooring Under Door Jambs
That's what she said...
Trade: Fan of Bodger
Re: How To Get T&g Flooring Under Door Jambs
lay it flat and beat it like it owes you money.
| The Following 3 Users Say Thank You to Crock For This Useful Post: |
LRG WoodCrafting
Lock it together and slide it under as one pc.
Re: How To Get T&g Flooring Under Door Jambs |
LRG WoodCrafting
Assemble the floor to the with of the hallway and slide it under the jamb. Or if it doesn't work scribe one side so it's perfect and snap and lock.
It's a floor, not rocket science.
cant picture your scenario with my pea size brain, but i have done many "t" hallways and yes you have to work backwards when you go around cased openings.
post a pick or drawing. edit; most of the stuff now has on side that doesn't need to angle to connect. if thats the case then you can run a joint at your problem area. Last edited by Crock; 07-03-2009 at 10:55 PM. |
Home Depot aisle walker
Trade: home remodeling
Woops see next post
fast fowrd to the 8 minute mark Last edited by Crock; 07-03-2009 at 11:03 PM. |
#11 | |
Lack Of All Trades
Trade: Professional handyman services
Re: How To Get T&g Flooring Under Door JambsQuote:
I haven't seen the laminate that won't lock up on the flat with the proper 'convincing' (a framing hammer and pine block). For a hallway on the diag. its all done this way as the end with the acute angle won't clear the wall. On the short side (obtuse angle) use a block against the flooring, another against the wall or base and a WonderBar to force it into position.
You also use the bar to close the gaps that will occur at the joints. Why diag.? Here it dates your home to 1985-mid 90's like diag. wall panelling to the '60's or Harvest Gold/Seafoam Green fixtures in the '50's. The last diag. floor that I did was Nov. of '01.
#15 | |
Trade: Floorist
Anyone else use the wood wedges for spacers, as suggested in the 'things you will need' segment? I swear by 'em.
• • • Greatness is a result of focused, deliberate practice • • • |
#16 | |
He's talking about a floating floor. Never nail that.
| The Following User Says Thank You to Home Work Pro For This Useful Post: | Darwin (07-04-2009) |
#17 | |
Knowledge Factory
![]() It is common knowledge for those that install a lot of rotating lock design, that in order to flat lay it, the lip on the planks mating, gets shaved off, and the planks then T&G glued, and tapped into place.
#18 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Another simple tip is to plan your plank layout to give you the easiest installation around door jambs and still maintaining at least ~ an 8" joint stagger. It is a common rookie mistake to not pay attention to how the rows are running out and leave yourself with a very aggravating piece to notch around a jamb and install. End joints placed in a thought out manner can make any install a helluva lot faster and easier. You can then use your tapping block to move a plank down to connect up with a previously installed piece instead of having to notch out in the middle.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#19 |
Very well put. Its all about planning the row so you are not trying to get a full plank under 2 casings.
I have used my little mini plane to skive off the locking mechanism but mostly use the utility blade in my pouch. I still have some of that Wilsonart glue too. It even froze on me 2 winters ago and still seemsto be fine. |
#20 |
Trade: flooring sales and installation
sometimes you will have to slide one plank under the installed plank and then take it under the jam then fit it into to already cut off locking t&g before its glued in place. just make sure its right because getting it back out is a b****.
| flooring or cabinetry first | coupe33 | Flooring | 68 | 10-06-2010 11:21 AM |
| Air waves under new vinyl flooring | geospec | Flooring | 26 | 05-08-2010 10:20 AM |
| laminate flooring placement | nwksremodeler | Flooring | 7 | 06-19-2009 10:24 AM |
| 6" T&G Oak flooring question | Leo G | Flooring | 11 | 03-08-2009 03:13 AM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
