How To Get Rid Of Smell After Re-staining Wood Floors? (Please Help)
Old 01-03-2011, 11:12 AM   #1
Fence Experts
Anchor Fence's Avatar
Trade: Fence Installation, sales and supplies
Rewards Points: 75
Hi,
over a month ago I sanded & re-stained the floors in my house. still to this day there is a strong smell in the house. I also painted the house but the smell is not one of paint.
I was wondering if anyone could share some advice as to HOW I can get rid of the smell of having newly stained floors?
Thank you in advance.
Michigan Vinyl Fence Company
Anchor Fence is offline
Old 01-03-2011, 12:04 PM   #2
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
Re: How To Get Rid Of Smell After Re-staining Wood Floors? (Please Help)
The smell usually leaves in just a few days. Have you tried changing the furnace filter?
RhodesHardwood is offline
Old 01-03-2011, 02:59 PM   #3
Fence Experts
Rewards Points: 75
Thank you for the response.
I have changed the furnace filter. Maybe I will try and trouble shoot a little more...
Any idea of how to eliminate such odors 'in general'?
Old 01-03-2011, 04:40 PM   #4
Erikfsn's Avatar
Rewards Points: 75
After redoing our floors the smell lingered for a while, then my wife found a bag full of rags in a corner that had some of the chemicals on them. The smell went away when the bag did.
Erikfsn is offline
Old 01-03-2011, 05:23 PM   #5
Floor Surgeon's Avatar
Trade: Hardwood flooring
Rewards Points: 75
Cross-ventilation is the best way to go. I am sure it is cold as hell in Michigan right now, but the method is to open a window on one side of the room and put a fan facing out and then open a window accross the room. Most HVAC systems do not change the air in the room fast enough to keep up with the solvents gassing off. You probably used polyurethane topcoats which will take much longer to cure and therefore continue to release solvents for a month or more. Waterbased finishes are a little easier on the nose to begin with and also cure much faster.
Floor Surgeon is offline
The Following User Says Thank You to Floor Surgeon For This Useful Post:
Anchor Fence (01-07-2011)
Old 01-05-2011, 10:50 AM   #6
astor's Avatar
Trade: FI
Rewards Points: 704
How about getting the dog into the tub and let him dry out in the house.That will eliminate any smell of poly.
astor is offline
Old 01-05-2011, 10:52 AM   #7
astor's Avatar
Trade: FI
Rewards Points: 704
You are such a lucky person, that may had cause a fire.
astor is offline
Old 01-06-2011, 01:17 PM   #8
CarpetbaggerEnt's Avatar
Trade: Restoration
Rewards Points: 25
I would look for any rags left in the house first. There are activated carbon air filters you can get for central HVAC systems that will scrub the odor out of the home in a day. Also, there are commercial air purifiers you can rent that will do the same - have used them in fire restoration jobs.
A cheap and easy method is new coffee grounds in pantyhose. Cut some squares out of a pair of panty hose big enough to hold 1 cup of coffee grounds. Tie them up and put them where air will circulate around them. The grounds will absorb the odors in a few days. It's an old trucker's trick they used in refer units - spread on the floor and wait 2 days - no odor.
CarpetbaggerEnt is offline
The Following User Says Thank You to CarpetbaggerEnt For This Useful Post:
Old 01-07-2011, 09:11 AM   #9
Fence Experts
Rewards Points: 75
Thanks for the tips! I did have the old lamb cloth(s) that were used for staining the floor still in the house in a garbage can (house was not currently occupied so the garbage was not taken out often) and I did use oil based poly.
I have removed the lamb cloth(s) and other rags that may have been used and will certainly try the "pantyhose/coffee" technique. Should I just place them near heater vents on the ground or anywhere on tables etc?
Thanks again for the assistance.
Staining and Sealing Wood Flooring HG Renovations Flooring 2 10-04-2010 09:35 PM
Staining Issues.. Paint Dribblz Painting & Finish Work 14 09-02-2010 09:17 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 03:45 PM
What type of Non toxic Putty with work on wood floors and accept Tung oil Stain? refinisher Flooring 1 01-16-2009 04:29 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 05:39 AM
