#21 | |
Re: Hickory Stair TreadsQuote:
In place would make for one tricky cut though. Maybe Leo, or Tom R, or one of the other guys have more insight. A thread titled steaming hickory or some such might get some attention, and I'm sure there is stuff on Google.
#22 |
Builder/Remodeler
Steaming is a lot to take on by yourself if you've never done it before. You can build your own jig, use a wallpaper steamer, etc. etc. but in the end I think that's a lot more work than building it in ply and I doubt you could get solid wood to turn that tight a radius without warping.
Do some searches: steam bending, cold lamination, vacuum bending, vacuum veneer, bending plywood, etc. This will stimulate your thinking for this project and for the future. An alternative--and the way most factory built-radius starting treads are made--is make to your own kerfs on the back side of 3/4" veneer ply and then bend it in place. Saw to within 1/8" of the finished surface and leave around 1/8" of meat between the kerfs. The best tool for this is a radial arm saw. Run the straight section long and cut it to length as you test fit. Wet the finished surface of the ply a little with a warm sponge to prevent the veneer from splitting. Sometimes it takes a few tries to get it to bend without a split along one of your kerfs. Norm Abram (New Yankee Workshop) has done about every iteration of radius finish carpentry you can think of on his shows. If you can find them on DVD, it would make a great addition to your library.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here Last edited by ChrWright; 10-12-2008 at 12:36 PM. |
#23 |
Trade: floorcovering
Re: Hickory Stair Treads |
#24 | |
#25 | |
I know Rockler woodworking store has many video How-Tos. I will look for Norm's radius work there. Thanks. |
#26 | |
Builder/Remodeler
If you're going to veneer it yourself, then use bending ply or kerf core.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
#27 | |
Builder/Remodeler
http://www.newyankee.com/index.php
#28 |
Trade: Hardwood Floors
I always put the riser in before the tread myself. Reduces your chances for gaps and then you don't need cove.
Cool bottom tread. Looks like a fun project. |
#29 |
I like Green things
I think Neo was talking about bending one solid board for the treads. Not for the risers.
#30 |
Nope, talking about the risers.
We did one with 3/8" oak, but it was more like a 16-18" radius and we got to make the step framing fit the finish rather than the other way round.
#31 | |
Regarding the cove, I hadn't intended to use it simply because I was going to make every effort to fit the treads tightly to the risers, just as you suggested. However, ChrWright opined that the absence of cove could be seen as 'cutting corners'. That thought sat with me all day. When I returned home this evening, I thumbed thru several issues of Architectural Digest. Sure enough, amidst all the photos depicting the finest in craftsmanship, the stairs always have the cove (or similar). I hope more members put in their 2-cents on this matter. I'll wait and see before starting a new thread.
#32 |
Neolitic, I know you were referring to the riser when making the comment, but humor me a moment.
After installing the risers, if I decided to use a cove molding under the treads, the radius at the end of the big bottom tread would certainly require steaming. I found the following design idea for a very lo-tech steam box in an issue of Wood (#175, March 2007, pgs. 56-57). ![]() You can see a few seconds of the same box by watching the beginning of this video. Since you have some experience with steaming wood, perhaps you can tell me what you think of such an undertaking. I may not use the cove, but, alack, if I wish to...
#33 |
Builder/Remodeler
I've been assuming all along that the risers & skirts will be hickory as well, as opposed to painted? Obviously from a woodworking perspective this is the highest level of finish. However, you might consider the alternative for cost and time. We often have to work within our clients' budgets and suggest alternatives which give them the biggest bang for their buck--while making our work look the best/most finished in the process.
It's still a very nice look to have natural wood treads, with painted risers, skirts, coves, shoes, etc. and creates a very nice contrast. However, it's hard to tell the look of the rest of the house to know whether or not this jibes with the overall design aesthetic. Curving and custom making the whole she-bang is expensive (or should be--I hope you're not giving your time away.) If you go painted on everything besides the treads, you can use flexible composite trims. These come in a variety of sizes and profiles. Food for thought.
#34 |
Looks good. You might search Fine Woodworking
as well. Obviously you will need a bigger box, and something bigger than a tea kettle. I have modified a square gallon can, and even a 5 gallon kerosene can, and use my propane camp stove for heat. The biggest "box" I've made was out of a length of 16"Ø PVC pipe.
#35 |
Chris has a really good thought there.
As to the risers? I usually do the bottom riser, then the second riser, then the first tread, then the third riser, then the second tread......
#36 | |||
Thank you immensely.Quote:
#37 | |
I was actually just thinking about standard skirt to skirt stair installation when I made that comment, sorry. None of the contractors or homeowners I've ever done stair work for wanted cove. They don't like how it looks.
#38 |
One setback I have had is that the 6 pie-shaped ('wedge'? What should I call them?) look like crap. I made them directly from paper patterns I had created on site. I may as well have drawn the radius from memory. I was stunned and ashamed at how wavy my cuts were. I will be making wood templates today and check them on-site. I lose a couple days and waste a bit of material, but I learned an important lesson. Specifically, wood templates: good.
I plan to purchase a stair wizard if I can hunt one down in town here. The six box stairs will go in last and I think this is a great job for which to finally make that overdue purchase. Thoughts? |
#39 |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
I couldn't imagine doing stairs with out mine. It just takes all of the work out of it, well worth the money.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
| Tags |
hickory, solid, stair, tread ![]() |
| Cutting stair treads with return 45 | nywoodwizard | Carpentry | 26 | 09-29-2010 08:31 AM |
| stair help | ravi2patel | Finish Carpentry | 9 | 09-13-2008 03:58 PM |
| stair treads | mmike032 | Finish Carpentry | 10 | 01-24-2008 09:25 PM |
| Painting stair risers and treads white | DeanV | Painting & Finish Work | 19 | 01-01-2008 12:10 AM |
| Painting stair risers and treads white | DeanV | Painting & Finish Work | 0 | 12-22-2007 12:05 PM |
