Help Vinyl Floor Has Huge Bubble!
Old 03-27-2005, 11:16 AM   #1
pixie340's Avatar
my kitchen floor has been down about 5 years. in the past month it developed a slight "lump" and a squeak ,felt like a loose board. then it rapidly went from bad to worse- 3ft by 2ft bubble. when you walk on it it gives. It was installed over luan. Is it possible that the luan has buckled?? There is also a smaller bubble on the other side of the kitchen. This is on the second floor over the laundry room. Please help!
pixie340 is offline
Old 03-27-2005, 11:55 AM   #2
Tom R's Avatar
Re: Help Vinyl Floor Has Huge Bubble!
Sounds to me like your luanne de-laminated, - - in other words, - - the glue between the layers gave up it's grip, - - sometimes installers use interior luanne instead of the exterior that should be used, - - in any event, - - time for a new floor.
Tom R is online now
Old 03-27-2005, 12:00 PM   #3
housedocs's Avatar
Trade: Home Improvement
Sure sounds like a subfloor problem to me, probably caused by water getting to the subfloor sheeting, luan huh, never cared for it as an undelayment.
"All you need in this life is ignorance and confidence, and then success is sure". -Mark Twain
housedocs is offline
Old 03-27-2005, 07:16 PM   #4
ccoffer's Avatar
sounds like a leak to me.
ccoffer is offline
Old 03-27-2005, 09:56 PM   #5
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Luan has been known to be a part of alot of problems.
Manufacturers usually drop warranties when it's used.
I suggest tearout of underlay, reinstall new AC Plywood, and then a new sheet of vinyl.
you should be good.
Floorwizard is offline
Old 03-28-2005, 07:55 AM   #6
pixie340's Avatar
we opened up the "bubble" and there is deffinently moisture between the layers of luan. pulled the dishwasher stove etc. cannot find a leak. we did have a leak under the sink a few years ago, could moisture have been trapped that long and only now causing a problem??? thank you for all the responses!
pixie340 is offline
Old 03-28-2005, 08:31 AM   #7
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Could it be steam/humidity from the washer/dryer below?
ProWallGuy is offline
Old 03-28-2005, 12:36 PM   #8
Tom R's Avatar
Yes, - - it definitely could have, - - and probably did cause the problem, - - and I think ProWallGuy's theory was also a contributing factor, - - that was also my initial thought before you had mentioned any leak.
Tom R is online now
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Scalloped Vinyl Shamrock Windows, Siding and Doors 1 09-18-2006 04:20 PM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
Vinyl on vinyl? reveivl Flooring 13 12-16-2005 07:00 PM
