Help With Some Various Installation Methods
Old 08-18-2009, 03:22 PM   #1
AcademyHardwood's Avatar
Trade: AcademyFloor
Glue Down Installations are considered to be much easier than the nail / staple down hardwood floor installations. The glue down method can be done as a Do-It-Yourself Installation by most home owners, by simply following the installation instructions. The greatest advantage of a Glue down installation is that it can be done on any sub floor. Unlike the Staple / Nail down method, which can only be done on a wooden sub floor. You can install the hardwood floor directly on a concrete slab or on tile, ceramic or plywood underlayments. Glue down installations are pretty much limited to Engineered hardwood. We strongly recommended not using the glue down installation method with solid hardwood floors, for the glue will limit the woods ability to expand and contract. Thanks to the multi-layered structure of engineered hardwood, it can be installed using the glue down method, making it fast, easy and cost effective.
AcademyHardwood is offline
Old 08-18-2009, 06:41 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Re: Help With Some Various Installation Methods
CLASS DISMISSED!!!!
the big 12 inch is offline
Old 08-18-2009, 07:46 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Please email Nathan (admin) and request that you would like to share your thoughts in the form of an article and it may be posted in the correct spot.
This area is not one of them.
Floorwizard is offline
Tags
hardwood installation
$199 Carpet Installation For Your Entire House. Celtic Flooring 68 06-28-2009 09:09 PM
Green roof installation in the UK Sam Milsom General Discussion 0 04-08-2009 08:06 AM
Finishing windows before installation??? nwksremodeler Windows, Siding and Doors 9 03-11-2009 08:32 PM
Methods to square a walkout foundation FRAMERBEN Framing 18 03-09-2009 01:12 AM
Exterior Door Installation BoydS Remodeling 59 02-20-2009 04:54 PM
