Help Bidding Commercial Tile Work
Old 03-11-2009, 09:51 AM   #1
UrbanTile's Avatar
Trade: Tile and Stone Installation
I own a tile installation company and mainly do residential remodels but have recently hooked up with a few companies that do commercial building and need advice on how to read their online bid sheets. I need to know where to find the specs for the tile and how to read the rest of the bid sheet. When I pull up the page it has the cover sheet, addendums, and a list of plumbing, finishings, hvac, etc, etc. Can anyone tell me how to just find and bid on the tile portion?
UrbanTile is offline
Old 03-11-2009, 01:36 PM   #2
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Help Bidding Commercial Tile Work
Finish schedule, along with a floor plan usually. Do you know how to do take-offs? If not you are about to get your ass handed to you.....just a warning. Research.
What happens when you miss 500sf, or pattern work, etc., etc., on your labor end and your bid gets accepted.....YOU eat it that's what. Bidding commercial work blind is about one of the stupidest things a tile man can do. It ain't residential remodeling friend, its a whole nother animal. Best of luck.
Precision Flooring
(772) 237-9900
PrecisionFloors is online now
Old 03-11-2009, 02:38 PM   #3
gumba's Avatar
Trade: flooring- tile/marble/stone/wood & laminate
My advice is to employ a seasoned commercial estimator. You would be surprised at how many little things are scattered in a) the written specifications, b)the actual plans and the c) addendums
gumba is offline
Old 03-13-2009, 10:18 AM   #4
bathroom guru
jarvis design's Avatar
Its not only the tile you need to be concerned about, its the expansion joints and other trim profiles that "should" be included in your specs.
Never fails to amaze me when I see a commercial tile job without expansion joints...nice crack you got there!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 03-28-2009, 11:42 AM   #5
Commercial Tile setters
dave peffer's Avatar
Trade: tile and stone
There are good problems and bad problems. You have a good one my friend.
There may be people who disagree, but here's what I do well, for the sake of discussion anyway)
Ask the builder for a set of blueprints and specs. If he provides them, you are considered a serious bidder usually- he wants your input.
If he won't provide them, go to the reprographics company listed, look over the architecturals and eliminate what you know you won't need like RCP's, furniture layout, kitchen equipment, etc. If you are going to do mud floors, you will want some structurals as well for considering the expansions etc. Once you know what you don't need BUY the rest. You will normally only need specs in your division 09300, but check for caulks and sealants too.
Don't try to estimate with some BS online blueprint service, you'll miss something for sure.
Start at the finish schedule, then one at a time build the entire job, including every special piece, on paper, (spread sheet). There are estimating programs out there, but if you don't build it, good luck.
Lastly, call me, for $500.00 I'll do it for you with an exact cost and scope of work to the letter. If you land the job and hire us to do the work, I'll refund the $500.00. -dpeff@ bellsouth.net (probably against the forum rules) Point is, commercial estimating is risky if it ain't perfect.
dave peffer is offline
Old 03-28-2009, 11:46 AM   #6
Did I mention there is no place for JUST the tile part? Just like tile, buildings are integrated projects, you gotta know whats going on around you man!
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
Any Plumbers looking for work in Boston, MA area? sadegs Help Wanted or Looking For Work 2 02-20-2009 07:45 PM
Commercial Drywall work Galveston, Texas Preston259 Drywall 0 12-21-2008 05:59 PM
Proposal for commercial work sttryffe Painting & Finish Work 1 09-30-2008 03:29 PM
Bidding Commercial Jobs JHezlep Electrical 2 10-04-2006 10:11 PM
