Trade: Home Remodeling
Help!!
We just installed an Bruce prefinished engineered wood floor. Some genius slid a piece of furniture across the living room, and now there are two long deprections. I say deprections because they are not scratches, but there are very noticeable when the light hits the floor right. It is an interlocking, no glue floating floor. To make a repair and change about 20, that's right, I said 20, boards in the middle of the floor, seems like a nightmare. Is there any way to bring the grain up to make them less noticeable?? Someone suggested putting an iron over a damp cloth, but that didn't work. Has anyone run into this problem before?
Re: Help!!
Hopefully the "genius" is not someone in your employ or that you are responsible for.
I always oppose engineered flooring for this very reason. Even pulling out a fridge without the proper precautions will turn into a costly repair. I've yet to see a product, or a repair that will fix what you have described. It's always ended up being a replacement of the affected units. Hopefully the die lot/run is still available or you have extra. Yes it is a nightmare. However, you are asking in the right forum. Lot's of talent around here and I would be curious too in hearing if there is a new innovation. Good luck.
220...221...whatever it takes! |
| The Following User Says Thank You to rselectric1 For This Useful Post: | RJR1969 (08-25-2010) |
SEMI RETIRED
Re: Help!!
I'm surprised the iron trick didn't delaminate the floor.
Re: Help!!
We tried it on a scap, just in case.
| The Following User Says Thank You to RJR1969 For This Useful Post: | angus242 (08-25-2010) |
MHIC licensed contractor
Trade: Home Improvement
Re: Help!!
The iron over a damp cloth is a very old trick, but i'm assuming the surface finish is preventing the water from entering the wood, which is essential to the first step of the trick.
The damp cloth and iron trick has 2 steps. Step 2 is to sand smooth, which im assuming you would wish to avoid. You could drag the furniture over the rest of the floor and sell it as a upgraded faux reclaimed floor. Try mixing up the drag marks with different types of large furniture.
Taz
Trade: General Contracting :Bathrooms and Kitchens
Re: Help!!
it sux..........however your only option is to pull up the pieces and redo them. if not you will be stuck with a bad rep...and it can impede ( mess up ) future business with customer and two other people they tell you f&cked up........up to you.....but it is the cost of doing business....sorry to be the bearer of bad news..but sometimes we have to step it up and be big boys...........
good luck |
Wood Craftsman
Re: Help!!
iron.....ah...that will not work , the lack of wood will not allow for that kind of lift on the grain....
........ going to have to rip it up...Brian. |
#8 | |
Trade: Remodeling contractor
Re: Help!!Quote:
Sit back, take a look at the scope of doing a real repair ...........and go for it. Don't skimp out. Don't try to minimize the task. Represent the clients' best interest. What if you were the client??????
Back in Maine Dubbin' Around Doin' good stuff ...... |
Wood Craftsman
Re: Help!!
despise that flooring.. honeslty.... the problems that can happen with that flooring are insurmountable.. if that was a "REAL" T&G wood floor..-"NO STAIN" that could have been repaired... you would have to recoat the entire floor for a level sheen ...but a lot less headaches....and it would not even show up after your done.......just like brand new
Brian |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Help!!
If it is a floating clic-lock floor, disassemble the floor up to the damaged boards, replace, and re-assemble. It's not as daunting a task as it seems. It usually takes me longer to pull the mouldings and move the furniture than it does to do the repair.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#11 | ||||
Flooring Guru
Trade: Sales Manager
Re: Help!!Quote:
That extra manufacturing process can score you some extra cash ![]() Quote:
Being a hero can bring in more money that you think you lose. Quote:
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Trade: floor leveling
Re: Help!!
Possibly sand the area in a very fine and detailed way. Then apply sealer or if needed some type if filler and faux finish the areas. Bummer.....
#13 | |
Re: Help!!Quote:
very fine and detailed way with a faux finish??????????????WTF
Flooring Installer
Trade: flooring
Re: Help!!
What is a "deprection"? Never seen such a word.
Flooring installer since 1973 Armstrong certified |
#15 | |
Re: Help!!Quote:
![]() Waaaay too much over-thinking going on in this thread. I gave the answer already
