Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-01-2009, 11:00 PM   #1
Trade: general
Hardwood underlayment
I will be installing some strand woven bamboo that will span multiple rooms. The subfloor is 3/4" OSB glued and nailed to the 16" joists. Half the floor has a 1/4" luan underlayment, the other half does not. I plan on installing a 1/4" underlayment under the half without to keep the transistions between rooms smooth and void of any reducers. So the question is weather to install more luan or if I could use 1/4" OSB which will reduce the cost. Or if there is any better method to keep the transistions smooth. Thoughts?
yamangold is offline   Reply With Quote
Old 02-02-2009, 12:47 PM   #2
copycat
mullaman's Avatar
Maybe rip up the existing luan? I don't know about the OSB... If I were to add, I would add the same as what's there already (luan). I would rip it out though. Are there any stairs to in the room?
strikes and gutters, ups and downs
mullaman is offline   Reply With Quote
Old 02-02-2009, 06:09 PM   #3
Knowledge Factory
Floordude's Avatar
They make ¼" OSB? Never seen it. What would its normal use be for?
If you can find it, it should work.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 02-02-2009, 06:26 PM   #4
Trade: Flooring
Send a message via Yahoo to Mike Costello
Ugh, you just brought back bad memories of Structure Board
Mike Costello is offline   Reply With Quote
3/4 T&G Hardwood floor underlayment options jdghandyman Flooring 16 09-03-2009 12:57 PM
Roofing Underlayment Offers MEL Marketing & Sales 3 12-12-2008 01:10 PM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 08:07 AM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
