Trade: Handyman
Hardwood Question
I read on the internet that you should lay wood floors perpendicular to the floor joists. How important is this? I am getting ready to lay 5/8" x 3 1/4 bamboo flooring and of course the way that would be easiest to lay it would be parralell to the joists.
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Hardwood Question
How thick, and of what material is your subfloor made?
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Trade: Building/Remodeling
To get my warranty on the installation I would require 11/2" subfloor to run with the joists or on an angle. Check with your manufacturer on their specs for proper installation but for me its an inch and a half.
#4 | |
Re: Hardwood QuestionQuote:
ALWAYS check manufacturers specs if possible
With a solid subfloor, direction doesn't make any difference. The 'perpendicular to joists' goes back to the old days when most homes didn't have subfloors just boards nailed to joists.
A lot of flooring specialists will tell you to lay with the light source. ID's will tell you that laying with the major length will make the room longer and with the minor length make the room appear wider. Can't make up your mind? Go on the diag., real trendy about 10 yrs. ago.
All other reasoning aside, - - laying perpendicular to the joists gives you a flatter floor overall . . .
Custom Builder
I think have a few questions here.
How old is the home? What type and condition of subfloor? Floating or true hardwood? Any dips and rises from joist crowning/movement? I think it's pretty straight forward, if any of these answers draw some concern, add additional underlayment.
Bob |
| Question for Hardwood and Carpet Guys.... | UpIACrete | Flooring | 2 | 02-21-2007 01:39 PM |
| Hardwood sales newbie: question regarding commission | servicetosales | Flooring | 3 | 01-28-2007 11:54 AM |
| Hardwood over hardwood? | dkillianjr | Flooring | 9 | 09-21-2006 09:07 AM |
| Hardwood question | Mike Finley | Flooring | 12 | 04-19-2006 07:13 PM |
